PC Soundcards - what to buy ?
Posted by: Steveandkate on 19 March 2004
Hi,
Can anyone shed some light on the subject - I am about to buy a new pc, and one of the main uses will be for compiling cd's from my vinyl and cds for my own use, obviously !
So, any suggestions as to what soundcard to go for please ?
Thanks,
Steve
Posted on: 19 March 2004 by Mike Hanson
M-Audio Audiophile 2496
-=> Mike Hanson <=-
Posted on: 19 March 2004 by Steveandkate
The perfect reply Mike - short and sweet.
Steve
Posted on: 19 March 2004 by john rubberneck
M-Audio Audiophile 2496 usb
Less noise
Stuart
Posted on: 19 March 2004 by Not For Me
Last Month's Future Music Magazine did a round up of all the main soundcards.
Echo, Terratec and Motu came out well for desktop machines.
Do you need MIDI / digital I/O / GM sound source ?
DS
OTR - The Now Show
Posted on: 19 March 2004 by jpk73
click here!
Posted on: 19 March 2004 by Eddie Pugh
Check out the RME Digi range and the Marian Marc 2 or if you want the best the Lynx 2
Eddie
Posted on: 21 March 2004 by Steveandkate
Ok - My needs are basic - just ripping and burning,and it will be plugged into either my old set-up or the Naim gear - so no need for digital I/O(I guess - tell me more..) no need for midi and as for GM sound source - what is that ?
As my compilations are made for in car or walkman use the utmost quality is not essential, but then again, some will be played via the stereo..
Cheers for your time guys,
Steve
Posted on: 21 March 2004 by Not For Me
Steve,
"so no need for digital I/O(I guess - tell me more..)"
This lets you take the PC sound output to a seperate, higher quality external DAC, and also get in data from other sources, or an external ADC.
no need for midi
i.e. no external keyboard module input / output
GM = General Midi, a standardised set of sounds used in some older applications to play tunes i.e. Sound 1 = Grand Piano ....Sound 128
You can download General MIDI files off the net and play them in bits, speed up, slow down, edit etc.
If you are after a basis set up, perhaps one of the Creative cards might be worth looking at, although they do have to change the smples rate to 48Khz internally. Terratec do a reasonable series of cards with good sound quality, multiple outputs if you want to do multichannel sound etc.
DS
Posted on: 23 March 2004 by Steveandkate
DS - You are being a whopper help here...
I have a naim CDX, XPS, 52/Super, plus a Marantz CD burner. I want to record a load of vinyl and cd's to the hard-drive of the pc to make compilations. That is all. The pc may well be connected to the hifi at times - So,do I need digital in/out for that..?
Midi and GM are not needed.
I do have an old DAC if needed, but can I not connect the pc direct to the 52 input/output for recording and playback..?
Many thanks for your help,
Steve
