Compatibility of Naim 250 power amplifier with Passive Pre-Amp
Posted by: MHYu on 19 March 2004
Hello
My current system is as follow :
1. CD Player : Marantz CD-7
2. Pre Amp : Audio Synthesis Passion passive unit
3. Power Amp : Conrad Johnson MV60
4. Loudspeaker : Sonus Faber Signum
Since I find a used Naim 250 power amp at a decent price, kindly advise the following issues related to its compatibility with my current system :
1. Does the Naim 250 work with my passive pre-amp?
2. Does the Naim 250 necessarily have to be used with Naim's own pre-amp for better effect of pace and rhythm? If so, does it work well with the old 32.5 pre-amp with Snap power supply? (I am considering this used pre-amp because of my rather tight budget at this moment)
3. Does Naim 250 offer much better pace and rhythm and dynamic punch than that of the Conrad Johnson MV-60?
I would like to keep using my CD player and speakers at this moment. Your advise will be much appreciated!
Thanks.
Hing
Thanks.
Hing
