wisdom wanted
Posted by: anselm on 18 March 2004
WhaTS THE PERCIVED WISDOM ON THE 202, I HAVE A 112 AND THOUGHT THAT THE 202 MIGHT BE A SUITABLE PLACE TO START,
THIS WOULD THEN FORM A REPLACEMENT FOR MY 112/HI INTO MY 180
Ta in advance
Anselm
all art is contemporary; it is the way we look at it that changes...
Posted on: 18 March 2004 by NB
Anslem,
Yes the 202 is a good place to start, a second hand 82 would be even better, however this may end up showing the defficiencies in your CD3.5.
Failing a good pre amp have you thought about a cdx?
NB
Posted on: 18 March 2004 by Naimed-In-NY
Anselm - I think the 202 is great preamp and represents excellent VFM. The 202 is considerably better than the 112, IMHO.
Posted on: 19 March 2004 by J.N.
Hi Anselm
You should really be aiming for a 200 to partner a 202. The 180 is fine in the meantime of course.
Don't forget the NAPSC with the 202, which independently powers the digital/control circuitry.
A friend has just added one and was staggered at the upgrade, for a fist full of dollars.
Particularly important, as it sounds like you already have a Hi-Cap?
Posted on: 19 March 2004 by prowla
I think my 82 tamed my CD3.5 a bit.
('course I then got a CDX...)
Paul
[This message was edited by prowla on Fri 19 March 2004 at 21:16.]
