N-Sat et al prices
Posted by: Jonathan on 20 February 2005
Please could someone let me know the prices of the new Naim surround speakers?
Jonathan
Posted on: 21 February 2005 by Neil Bennett
I believe they're £850 including the specific stands.
Neil
Posted on: 24 February 2005 by Neil Bennett
Correction: just checked and they're £890.
Neil
Posted on: 24 February 2005 by Adam Meredith
nSATs - £695
nCENT £500
nSUB £1,495
nSTAND £195 (NOT Flimsy - just small boned).
Posted on: 26 February 2005 by pingu
Hi Adam
Is that [nSAT] price per speaker, per pair or for four of them or what?
Posted on: 26 February 2005 by Jay
Originally posted by pingu:
Hi Adam
Speakers usually come in pairs. n-Sat is no exception.
Posted on: 26 February 2005 by Matt F
It's not unusual to be able to buy sats in single units - after all you may want to use 3 across the front (to give perfect matching).
Does anyone know if you can buy a single nSAT?
Matt.
Posted on: 27 February 2005 by Adam Meredith
Originally posted by Matt F:
[QUOTE]Originally posted by Jay:
Matt.
NO - but you can buy a third of a sub. Most people would give some consideration to the nCENT for perfect matching to the SATs.
Posted on: 27 February 2005 by pingu
So Adam, do you think you could possibly answer the question. Is the price for a pair, one or more than 2 or what????
Also what would go with an AV2 52 500 nbls - presumably you would recommend the bigger centre speaker with a single mono amp (V145?) but would nsubs work at the back on the end of a nap250?
cj
Posted on: 27 February 2005 by Matt F
So, if the matching is perfect you'd be happy to use one nSAT and one nCENT in a stereo set up then?
Don't get me wrong, I've had some very good 'matching' centres but you can't beat 3 identical front speakers.
Matt.
cj
nSATs - price for a pair
nCENT - price for one
nSUB - price for one
nSTANDs - price for a pair.
Posted on: 02 March 2005 by Frank Abela
pingu
You'd be better off with an Axess or Axent centre speaker. The reason for this is that the main drive units in those centres are the same as the midrange unit in the NBL and so is voiced much more like that unit. Naturally, the NAPV145 is the best match, especially since you've got a 500.
At the back, the n-Sats would do a good job, but the Allae would be better since the drive units are Naim's own once again. The 250 would do a fine job driving either N-Sats or Allaes.
Finally, although your NBLs may seem more than enough for bass, you really want to try the N-Sub in this system. You *will* be surprised at how effective it is.
Posted on: 02 March 2005 by Adam Meredith
Also - remember that the LFE (Low Frequency Effects) channel is specifically intended to drive a subwoofer.
