Calling the Swiss "Naimies" re power cords
Posted by: uem on 04 February 2005
Hoi Zäme (.. Swiss slang for "G'day"..)
I started the thread below.
http://forums.naim-audio.com/eve/forums?a=tpc&s=67019385&f=48019385&m=55910812
What are your thoughts ?
Which brand power cord did you get with your Naim gear ?
Are you acutally using it? I'm using audio agile cords, which were recommended by my dealer.
Urs Marti
Posted on: 04 February 2005 by DF
Audio Agile power cord is good.
I use it myself in my system.
You should also try Van den Hul power cords: so much better and very competitively priced.
Van den Hul Mainstream for power amps and Van den Hul Mainserver for cd players and pre-amps.
Posted on: 04 February 2005 by Tigger24
With regards to power cables i would be careful which ones you use as naim state that the uk leads MUST have a 13amp fuse in the plug so it won't blow, and presumably there power cables are made using 13amp flex, the mainserver is only designed to carry 10amps.
Posted on: 04 February 2005 by mattbr
I'm using a Graham's hydra (yeay!).
you order the stock one and change the plug. Or get a local electrician to change it for you. Asked my dealer about Naim plug quality, he said anything that's halfway good should do the trick.
Posted on: 05 February 2005 by Tigger24
Regarding plug quality, go for a nice permaplug or duraplug both should be around £1.30-£1.50 in wholesalers, avoid rs as they rebadge the duraplugs and volex plugs as rs and diy stores as they are a rip off at £2.00 a time, or go for the mk safety plug £1.98 in white £2.25 in black but again probably cheaper in wholesalers.
