Cameras from usa?
Posted by: roman on 23 March 2004
I'm looking into buying a pentax camera from the states, the dollars so weak that I feel I could justify the expense of an otherwise ovepriced model (the mz-s, probably to be my last ever 35mm purchase), however I'm not sure whether any guarantee would be valid over here, and I understand that goods can be intercepted and duty added.
Do any of you have experience of this happening? does it help if you package it a certain way? Can you recommend a reliable vendor stateside?
cheers
roman
Posted on: 24 March 2004 by David Stewart
On an item of high value like a camera you will almost certainly pay not only import duty but VAT as well. There's no way around this because the supplier will have to make a declaration of the package contents and value. Also worth noting you pay VAT on the total amount including the carriage charge and the duty. So you should allow a minimum of 25% additional to cover these charges, plus of course the carriage cost itself.
Posted on: 24 March 2004 by P
Anyone know if the same VAT and duty applies to used goods?
Like say an expensive guitar from the USA?
P
Posted on: 24 March 2004 by Geoff P
On the plan to buy a 35mm camera are you after just after a body for an SLR system which you already have lenses for?
Or are you talking about the whole thing starting from scratch, lenses and all?
Also if this is to be the "last" camera purchase you have picked a time when there is amajor crossroad in 35mm photography. Whether to stay optical or go digital?
IMO the evolution of Image Sensors for cameras is accelerating and will, if not already there reach to the level of imaging AND photo efects that can be acheived with film very soon.
Have you considered an SLR system based on either a Nikon or a Canon digital back in combo with appropriate focal length lenses?
On the topic of getting it cheap in the USA.
The following option is something to consider though it is a personal decision as to how you feel about it's legality, it could be construed as smuggling.
Vist the US on holiday and buy it personally then bring it back unpacked and looking like it has been in use for some time.
The other big issue is the warranty etc. will not work if you do not have an american address on the so called "international warranty" form especially with electronics which are often "dedicated" to specific markets and use model numbers which are not even officially listed in europe.
just some thoughts
regards
GEOFF
Posted on: 24 March 2004 by roman
I already own three pentax lenses and two bodies. Although theres no question that digital represents the future, £400 will buy me an exceptional 35mm body, a high quality digital body will cost substantially more. With the rapid evolution of digital and, admittedly falling prices, any delay in purchasin can only work to my benefit. The clincher lies in the fact that my pc and printer are of a low spec, somthing that would entail further expenditure in the region of £1000 to make it worthwhile.
What really appeals about the mzs is its imprinting function. All technical details of each photo are included along the edge of the negative. To date I've been hopeless at noting aperture and shutter speed for my photos, and consequently I've struggled to learn from my pictures. This function should do the trick. Otherwise, one or two deficiencies apart its supposed to be a small, light rugged camera with good handling.
Geoff, your idea of buying abroad is a good ne. I have a friend who comes over once or twice a year. I'm sure she'd agree to be my mule!
cheers
roman
Posted on: 24 March 2004 by jpk73
I bought a Pentax in Japan with Japanese warranty card and they sent me an international warranty card for free. It was just one phone call!
Good luck,
Jun
