Is it possible to have a prefix type s reconfigured to type k anyone any idea of cost?
TIA
Sean
Posted on: 09 April 2004 by Manu
Yes, it is possible.
For costs you should contact Naim or your dealer or the distributor.
Emmanuel
Euphonie
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 09 April 2004 by Bosh
I recall it requires only one component change and was done free of charge by my dealer in a couple of minutes when I had my Dynavector fitted a few years ago
Posted on: 10 April 2004 by Manu
With the purchase of a cartrige, i do it for free also.
But if your prefix is not new, you should ask for the upgrade also, it is IMO mandatory with a K version: no more RFI problems and sounds better.
Emmanuel
Euphonie
