Safe DIY disconnection of IR receiver on NAIT 3r
Posted by: Potiriadis on 06 April 2004
Dear Forum
Further to my recent post on wife safing a hifi system I have come to the conclusion that the best way forward is to actualy disable the remote sensor completely. On a previous amp I did this with the careful placement ofa velcro cover ofver the sensor. This Heath Robinson solution was perfectly adequate on my previous budget amp, but is not desireable for my NAIM kit. I was wandering how easy it would be to simply disconnect the IR sensor inside the case. Is this something I can do with a pair of pliers or should I tahek the unit into my local dealer. I almost never use the remote on the NAIT, prefering the tactil pleasure of the volume and selction controls on the unit.
Help Bunnys everywhere!!!!!
No Seriously, everywhere!!!!!!!
