Dead 52
Posted by: andrew jameson on 07 August 2000
Went to listen to some music last night and discovered that my 52 had died ie. no signs of life / light on either the SC or the head unit. Have tried swapping the power cables from other components to no avail. Anyone got any thoughts??
Posted on: 07 August 2000 by Kevin Hughes
Sounds like the Supercap has died, maybe Cliff can lend you one of his spares whilst it is in for repair
Seriously, go to a dealer, and start praying it is cheap.
Kevin.
Posted on: 07 August 2000 by Former member
I believe the Supercap has an internal fuse which would be worth checking.
Simon
