The Lure of PRaT
Posted by: Mike Hanson on 19 September 2000
Just a little history for you: Cambridge has been making budget, one-box CD players for a few years now. Their old CD4SE was described as a "giant killer" by many, and I figured it would be good for my office system. I couldn't stand my old office system after upgrading to Naim gear at home, and I didn't want to spend too much money.
I was actually quite happy with the sound of the CD4SE. It was a tad rough sounding, but it did the PRaT thing well. Unfortunately, I had problems with tracking due to the electrical power in my office. The local Cambridge distributor here in Canada (Plurison), was quite helpful. They eventually did a free swap for the new D500. Although I wasn't able to test them side-by-side, the D500 seemed very similar to the old CD4SE.
Meanwhile, the CD6 was the supposedly one step up from the CD4SE. I had heard some suggest that the CD4SE was actually more "fun" than the CD6, though. You can't buy a new CD4SE or CD6 today (unless it's old stock).
As it's always hard for me to be patient, I had to try it straight out of the box. Initially the CD6 seemed much more refined than the D500. Everything sounded smoother and more natural (almost "analog" at times). Details that were entirely masked by the D500 were blatantly obvious with the CD6. Bass was much more controlled. It also handled intricate phrasing much better. In contrast, the D500 seemed occluded and harsh. All in all, the CD6 seemed to be the better player.
After a while, though, the scales started to tip. I realized that there were two things that the D500 did do better: The bass had a little more slam, even though it was a touch bloated. It also seemed to have more boogie! In other words, it was more exciting to listen to the D500, even though it was mixed-up, harsh, and edgy, with a semi-bloated bass. So what was I to do? I really liked the ability to see "into" the music with the CD6, yet I found myself getting a touch bored.
As I mentioned earlier, I had tried the CD6 when it was cold. After warming up for a day or two, it started to swing a little more, although it still didn’t' have the same boogie factor of the D500. In fact, some recordings seemed almost sedate when played on the CD6. Each time I tried the D500 I said to myself, "Listen to that bite! It sure is fun, but it's also noisy." (This perception seemed familiar to me, as it was pretty much how I felt about my CD3.5; the CDX cured my problem there. This also may be why a few people think that a 3.5 is more "exciting" than a CDX.)
Now here's the twist. The CD6 comes with both RCA and balance XLR outputs. I had an old Naim interconnect sitting around (after upgrading my cable at home to the new lavender variety). I decided to replace the connector on the source end of the cable with an XLR, then rewire the inside of the CD6 so that one of the two XLRs could feed the Naim cable. I was already using a Chord Cobra 2, though, so I wasn't sure how much of a benefit this would give me.
After hooking it up, I was able to do quick A/B comparisons between the RCA and XLR outputs. I was happy to discover that it added a bit more bite, as well as increasing the swing. The presentation also seemed more focused and precise, which may be why I was perceiving more bite. When I removed the cable connected to the RCAs, leaving the XLR as the only output, the sounded improved a bit more (due to reduced load on the CD output, I suspect). Naim cable and wiring wins again!!!
So I've decided to stick with the CD6 for now. Although I still think it doesn't boogie quite as well as the D500, it does almost everything else better, including helping me to follow the music. I can give up a touch of drive and energy for that gain. Perhaps I'll tire of it in a while, but I can always go back to a D500 if I really want to, or I could upgrade to something better.
This also makes me wonder about Pace, Rhythm and Timing (a.k.a. PRaT) in general. Although I'd realized that all of these are supposed to be individual yet related traits, I've always just lumped them together. If a piece of gear had good PRaT, then it would be lots of fun, with a sense of swing, slam, boogie, movement, phrasing, emotion, etc. Every player that I had auditioned before the Cambridge CD6 either did PRaT or it didn't. In the case of the CD6, it seemed to handle phrasing and swing, but didn't have the sense of drive that the D500 provided.
So what was the CD6 missing: Pace, Rhythm or Timing? Have the rest of you usually found that all three come together? Is it that some manufacturers "get it", while others don't? What is each of these elements of P, R, and T supposed to bring to the table? I seem to remember seeing a good explanation somewhere, but I can't recall whether it was on the old Naim forum or somewhere else.
Curiously when the CD6 was behaving "poorly", the soundstage always seemed much better than the D500's. When I changed to the Naim cable, the soundstage didn't seem quite so obvious. It makes me wonder how much credence to give to those who feel that "magic" soundstage and PRaT are mutually exclusive. Hmmm.
Catch you later!
-=> Mike Hanson <=-
Smilies do not a forum make.
