Calling Sony Ericsson P910i owners?
Posted by: Hawk on 02 February 2005
I keep thinking about one of these but have a couple of concerns that i would appreciate some feedback on...
How do you find the battery life? I use a K700i mobile at the moment and it usually just sees the day out on an overnight charge.. the 910 would be no good to me if it gives up too easily... DOes anyone use one quite heavily?
Secondly, synching with a PC... im sure it will talk happily to MS outlook etc but mine would need to talk to lotus notes.. can anyone shed any light on if this would work easily?
thanks in advance
Hawk
Posted on: 02 February 2005 by Tony Lockhart
My P910i manages a day a heavy use quite easily. The power hungry apps videos or gaming, so unless you are seriously into that you should have no worries.
The battery level indicator works by percentage, which is more accurate than the 3 or 4 bars normally shown, and even on less than 5% power, a 20 minute call would be possible.
By the way, I leave my bluetooth on, and schedule the email checker for every 15 minutes..... both power hungry habits.
I'm afraid I can't help with Lotus notes, sorry.
For some idea of the apps available:
http://www.handango.com/sonyericsson/PlatformHome.jsp?siteId=784&javaDevice=P910&device=P910
Tony
Posted on: 02 February 2005 by Hawk
Thanks Tony, the battery life sounds promising.. I too would use bluetooth quite a bit but i wouldnt probably get much time for the games or video during the day..
cheers
Hawk
