ARO-cartridge fixing compatibility
Posted by: Brucie on 15 April 2004
I have just had an ARO installed on my LP12 with a Dynavector DV20 cartridge. Seeing as there are only 2 holes to fix the cartrdige that means one cannot adjust the azimuth (right?).
Does this matter? I understand the dynavector cartridges are a good match with the ARO so does that match extend to the physical matching as well as the sound perhaps?
It sounds fine enough and I can hear major improvements over my Ittok.
Comments welcome.
Bruce
Comments welcome.
Bruce
