Any computer teckies out there
Posted by: Mick P on 03 April 2004
Chaps
I seem to be having PC problems lately.
I can use this PC for surfing the net and sending emails etc.
My problem is that I have lots of spread sheets and pics filed away under my C drive and if I click on to retrieve them, one of two things happen.
1) It takes a minute or two for the file or pic to appear.
or
2) Nothing happens and then I get a message saying " there was a problem in sending a command to the programme." Therefore I cannot access the file or pic.Then the screen freezes and I have to reboot.
Any idea what the problem could be.
Mick
or
Mick
Posted on: 03 April 2004 by Cheese
what OS ?
Cheese
Cheese
Posted on: 03 April 2004 by Mick P
Sorry but I do not know what OS is.
Mick
Mick
Posted on: 03 April 2004 by Jez Quigley
OS = Operating system. e.g. Windows 95, 98, 98SE, 2000, NT, XP, Linux etc.
Posted on: 03 April 2004 by matthewr
Mick,
Almost certainly caused by a bug in ZoneAlarm firewall -- so if you are using that try switching it off to see if it the problem goes away. If it does download and then uninstall and re-install the latest version.
Matthew
Matthew
Posted on: 04 April 2004 by Mick P
Thanks for the prompt replies on a Sunday morning.
The system is Windows 98 and I use Norton not Zone alarm.
Mick
Mick
Posted on: 04 April 2004 by David Stewart
Assuming this PC isn't networked, I'm not sure why a firewall problem should cause difficulties accessing files on your C: drive. To me it sounds more like a file corruption or even a disc controller problem. Have you run a full disc surface scan recently? or a defrag?
Posted on: 04 April 2004 by matthewr
There was a known issue in ZoneAlarm which gave exactly this problem.
It was caused becuase ZoneAlarm thinks that you are acessing the Internet when Windows Explorer does certain innocuous operations like traversing shortcuts, opening files via association, etc.
Matthew
Matthew
I conducted a disc scan and tried to do a "thorough" but gave up after 14 hours. I then successfully did a standard scan and defragged afterwards.
Mick
Mick
Posted on: 04 April 2004 by BigH47
Mick
I have always got good help from Tech Support Guy(TSG) http://forums.techguy.org/ free and usually quick. Just go the forum for your O.S.
Howard
Sods law they are down for maintence.
Howard
Posted on: 04 April 2004 by Andrew L. Weekes
I'm with David, based on limited evidence, it sounds like the symptoms one gets when a hard drive is on the verge of giving up.
Mick,
Click 'Start', point to 'Settings', click 'Control Panel', and then double-click 'System'.
Double-click the 'Disk drvies' branch on the Device Manager tab.
Make a note of what that entry says and post it here, we can then direct you to the hard drive manufacturer's utility to test the drive.
Andy.
Mick,
Andy.
Andy
I did as you suggested. It took about 2 minutes for the control panel to be displayed after clicking on settings and once I got into disc drives it said "this device is in order".
Mick
Mick
Posted on: 04 April 2004 by quincy
What available space is left on your drive?
Posted on: 04 April 2004 by Former member
Try cleaning the hard drive (Start/Accessories/System Tools/Disk Clean Up) and the Defrag the hard drive.
If the problem persists see what programmes are running in the background and try turning some of them off.
I remember I had a similar problem at work, unfortunately I can't remember how I fixed it.
(or maybe it's your mains
Tom
Actively enjoying it all
Tom
I am using 26% of avaialable disc space. I have drgragged the system and did a standard scandisc.
Mick
Mick
Posted on: 04 April 2004 by ken c
does this only happen when you try to access saved spreadsheets -- i am assuming none of the spreadsheets are already open.
do you get the same problem when you try to access saved word documents, for example?
also try the following: when the system is in this limboland, click right in the task bar (bottom of the desktop) and select Task Manager (this may take a while if your system is suffering, but be patient).
click on the cpu header to sort the entries in descending order of cpu consumption.
tell us the top 5 tasks.
do the same for memory usage.
enjoy
ken
enjoy
ken
Posted on: 04 April 2004 by Phil Barry
Spyware is another possibility, but I lean towards HDD problems (including data corruption due to s/w), too, in the absence of other info, base on this assumption: a W98 PC is likely to be 4-5 years old, towards the end of life for an IDE hard drive.
Mick,
Copy any data you care about to other media (zip, CD, floppy if you have to). Then get a new PC - it will be cheaper than screwing around with this one, sicne you can't do it yourself.
Regards.
Phil
Mick,
Regards.
Phil
Posted on: 04 April 2004 by Mike Hughes
Mick,
It clearly can't be Zone Alarm if you don't have it but I am equally unconvinced by the HDD suggestions. Here are some other things you might want to investigate?
1) Is it only certain file types? If so then tell us what or try out a few others and find out.
2) Clear out as many temp/tmp files as you can.
3) Have you recently installed RealPlayer or similar? Sometimes faulty downloads of these can cause exactly these symptoms.
4) Where do you save most documents? Is it in your C:\ or is it in another folder like C:\My Documents\Mick Parry etc? Saving too many files in your root folder can cause swap file problems and provoke exactly the symptoms you describe. Also, scandisk and defrag would then run as slowly as you describe.
Don't give up just yet as I have a few other thoughts too.
Also, in case of potential HDD failure make sure you have backed up all required documents; software patches etc. AND don't just back up. Make sure you can actually access them if needed - a common failure of people backing up.
Happy hunting.
Mike H.
Happy hunting.
Mike H.
Posted on: 04 April 2004 by Stevea
When was the last time you re-booted your machine?.
My home PC sometimes becomes extremely slow (5+ minutes) at opening Excel or Word either directly or via selecting one of their files. Re-booting has so far always fixed this but the machine is in dire need of a rebuild which probably means I will just get a new one.
Steve
Steve
To answer your questions
It seems to be anything I have downloaded.
I do this regularly
I installed RealPlayer a long tima ago, before all this started.
I have had a good clearout and deleted loads of stuff but it still persists.
Mick
I do this regularly
Mick
Posted on: 05 April 2004 by Mick P
Chaps
I gave the disc a thorough scan overnight and it said that all errors had been corrected. I then defragged it which took about 45 minutes.
However the problem still persists.
Do you think the time as come for me to get it looked at professionally.
Mick
Mick
Posted on: 05 April 2004 by Paul Ranson
If you could carry it on your bike you could cruise up the A421 for 45 minutes or so and I would be able to sort it out for you.
Paul
Paul
Posted on: 05 April 2004 by David Stewart
Mick,
You may well be better off to get someone to look at it. Its pretty difficult to diagnose some system problems without being able to sit in front of it and see whats happening. If you can't take up Pauls kind offer you may well find in the Swindleford area, there's several PC Support people who do home visits advertisng in your local free paper. If possible, try to get one who'll work on a 'no fix no fee basis' or else a fixed up front cost. Good Luck!
PS: something else just occured to me. Are the troublesome files particularly large ones and how much RAM memory do you have in the PC?
Posted on: 05 April 2004 by matthewr
Mick,
"It seems to be anything I have downloaded"
What sort of files? Any and all files regardless of source or type?
Do you get this problem if you open the file from "File Open" within the application or just from opening via a click?
You mentioned Excel documents is it just these and other Office documents or all types of files?
Does it happen if you create your own files locally or does it have to be downloaded files?
FWIW Given that this *exact* same problem with Windows Explorer has regularly occured with ZoneAlarm I'd try turning off your firewall anyway just in case. I'd also try disabling your Anti-Virus software especially if this problem is strongly associated with Excel and Word files.
Rather than pay someone to come and fix it, I would first consider doing a full clean re-install of your PC from your latest set of backups. In my experience that's got an 90% chance of fixing it and it will likely improve your performance and reliability anyway.
Matthew
Matthew
Posted on: 05 April 2004 by Martin Clark
Download and run both these anti-spyware programs:
Spybot
Lavasoft Ad-aware
Both are trusted, and recommended.
Spybot
Lavasoft Ad-aware
Are you saying I should ininstall every programme and then install them.
Martin
I have ad aware and use it daily.
I have uninstalled Real player and Windows Media player and the problem is still there.
Mick
Martin
Mick
