Rega Planer 3: sounding thin
Posted by: kj burrell on 16 March 2004
In upgarding my system over the last six months I've moved from an Arcam 8R/Rega Planet to Nait5/CD5, all of which sounds great burt it has left my Planer 3, now run through a Rega phono with Chord Chrysalis ( I think) interconnects, sounding quite thin and tiny. It used to sound better than the Planet by some way. Is this just because the CD5 is such a big jump that its left the P3 behind? Is it possible that the Phono gives a thinner sound than the integral Arcam phono stage? Is there a simple ( ie cheap) answer or do I bide my time until upgrade resources become available?
Any thoughts?
Kevin
Any thoughts?
Kevin
Posted on: 16 March 2004 by kj burrell
excuse the typos - left my glasses at home and can't proof read on the little letters! It should, of course, say sounding tinny, although tiny may be a better word after all.
Kevin
Kevin
Posted on: 16 March 2004 by domfjbrown
What cartridge?
I have a CD5 and Planar3, and until I got a second hand Flatcap, the CD5 was sounding FAR thinner than the Planar3 (with Ortofon 540/PSU upgrade/Flutterbuster/Naim phono cards).
I'd suggest having a look at the setup of the cartridge, though maybe the phono stage you're using isn't helping?
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
Posted on: 16 March 2004 by JonR
Hi KJ,
I too have a Planar 3 as well as a CD5, though I run them through a NAC112/NAP150. I find I am very satisfied with the sound and believe it holds up well compared to the CD5 (which also benefits from being attached to a FC2), however I have applied a couple of modificationa to it which I believe has had definite benefits to the sound:-
1) I had it 'P3' modified, ie. the motor was changed to that used for the Rega P3, the current replacement for the Planar 3 in Rega's turntable lineup.
2) It is now fitted with the Super Elys MM cartridge, which is probably about as good a cartridge as you would ever want to fit on this turntable before considering a TT upgrade.
I do also of course use a Stageline, which also benefits from being powered by the Flatcap 2.
Hope some of this helps.
JonR
jonreefe@aol.com
JonR
jonreefe@aol.com
Posted on: 16 March 2004 by Lo Fi Si
Kevin
If you can, try putting the Planar3 on a Rega wall shelf (about £40 now, I think). This made a huge difference to the bass on mine - increased and tighter bass. The motor upgrade ( as recommended by Jon)is also worthwhile.
Simon
Simon
Posted on: 16 March 2004 by glevethan
Hi
Please look at my posting
http://forums.naim-audio.com/eve/forums?a=tpc&s=67019385&f=48019385&m=7191965696&r=3001946696#3001946696
in which I discuss my experience of replacing my P3 within my Nait5/CD5 system. Interesting reading.
Gregg
Gregg
Posted on: 16 March 2004 by Pictish
Kevin,
I have almost the same setup as yourself Planar3, bare CD5, Nait5, except I use the Naim Stageline phone stage.
For a while I had the Planar running through the internal phono stage on my old Audiolab 8000A amp. Moving to the Stageline was a huge upgrade, a much cleaner but also a more full-bodied sound, definitely not a "tinnier" sound. Taking an album which is well recorded on vinyl and CD (Kenny Burrell, Midnight Blue on Blue Note) I can compare the CD5 with Planar3/StageLine. Result - very difficult to tell the difference, both sound boogie-tastic. On a blind test I really couldn't guess which is which.
So I reckon it could be TT setup/cartridge/phono stage that is causing the "tinny" sound. Perhaps the Arcams internal stage is superior to the Rega - one way to check (if you still have the old amp) is to connect through the Arcams phono stage (via the monitor or Tape loop).
Mike
Mike
Thanks for these. Maybe looking out a second hand stageline would be better than upgrading the whole turntable. It seems to be the only factor separating my system from most of the above. I would still probably need this if I upgraded the turntable anyway. Do you need a fc2 to run the stageline? Any good sites to check out availablilty of 2nd hand stagelines? I was hoping to get one sooner rather than later to further sharpen the CD5/Nait5. I feel a debt crisis coming on!
Kevin
Kevin
Kevin,
I'm running a Stageline direct from the Nait5. Second hand or ex-dem ones go for around £120.
Mike
Mike
Kevin,
I believe you can run a Stageline off one of the sockets at the back of your Nait5, but I would definitely recommend getting a Flatcap2 - it's the only one of Naim's power supplies that can power more than one device, and I derive maximum use (and value!) out of mine because I've got the Stageline, CD5 and NAC112 all plugged into it!
JR
jonreefe@aol.com
Jon,
You're powering 3 components from the Flatcap2? I'd like to know how you do that!
Mike
Jon,
Mike
Mike,
Errr....I thought it was all there in the instructions.....! Unless, of course, I have missed a warning which says that the FC2 can only power 2 devices max! I'll have to double-check! Thanks for the 'heads up'!
JR
jonreefe@aol.com
OK, checked the manuals and the system and I now realise I was completely wrong! The Stageline is in fact connected to the aux2 output of the NAC112. Apologies all round for the cock-up!
Kevin, as per one of Mike's earlier posts, you can connect a Stageline to your Nait5.
It does make me wonder though...what would it sound like if it was powered directly by the FC2...?
JR
jonreefe@aol.com
JR
jonreefe@aol.com
Posted on: 28 March 2004 by kj burrell
Thanks for the comments: bit slow getting round to it, but sent the P3 ( not a Planer 3: der!) in to have a Super Elys fitted. Due back later in the week. I'll post the results.
Kevin
Kevin
