AV2, DVD5 and Loewe ready remote
Posted by: drps on 20 February 2005
Has any one had experience with the AV2 and the Loewe ready remote.
I have set the AV2 to the Loewe ready remote and the AV2 now responds to the remote.
But now does not respond to the remote for the DVD5.
I would like to use the joint DVD5 remote to control both.
I have tried to switch the AV2 back to the DVD5 remote but it did not appear to work.
First by using the DVD5 remote and then by setting back to the defaults, with no success.
How do I switch the AV2 back to work with the DVD5 remote?
Is there a DVD5 Loewe ready remote?
Can I get a std AV2 remote?
Thanks for any help
Paul S
