50Hz peak
Posted by: marczed on 01 April 2004
Greetings.
I have been a naim user since November of last year.
System -:
NAC252 + Supercap
NAP300
CDX2 + XPS
Naim Allae
Over the years I have owned a few different systems. Whilst this one is by far the best, I still suffer from a distracting and pronounced peak at around 50Hz which is sufficiently dominent to mask lower frequency bass. I have tried every available speaker position (within reason).
I can only assume that it is the shape of the room that is the cause of the problem. It is 'L' shaped. The 'main' part being 20' long by 12' wide and the 'other part' being 9' square. I have tried 'firing' down the length of the large part as well as across the smaller width of the room. This makes no difference to the 50Hz resonance, but the imageing is much better firing lengthwise, so thats how it is set up.
Question -: would I achieve a better balance by upgrading the speakers to a larger type capable of going lower? I realise that the only way to find out is to try some, but any comments would be helpful.
PS I used a CD test disk with frequency sweep which clearly makes the room 'take off' at around 50Hz.
System -:
NAC252 + Supercap
NAP300
CDX2 + XPS
Naim Allae
