TT upgrade challenges CD5
Posted by: SB on 29 April 2004
I now know what all the fuss is about with Vinyl. Earlier this year I finally ditched my ageing CD Player and went for a CD5 with FC2. Sounds fantastic, but then my 20 year old turntable was the weak link. Systemdek IIX with Linn Basik LVX and Nagaoka MP11 MM Cart.
So I invested in a Goldring 1042 cartridge and more significantly an OriginLive motor upgrade. Wow did that make a difference!!
The detail and sound quality that this setup pulls of the disc is fantastic and for a relatively small investment.
Only problrem now is that it is beating the CD5, but I guess that is what uprading sources is all about.
Rest of system is NAIT5 and Dynaudion Audience 50.
Posted on: 29 April 2004 by glevethan
When I purchased my Naim system this year-Nait5 and CD5- I also purchased a Rega P3. I felt that the CD5 outshined the Rega. Since I have quite a bit of Vinyl that I wanted to start listening to again (this was also the reason for the Nait5 instead of the 5i-it powered a Stageline)) I decided to give back the Rega and go for the "big KAHOUNA"- LP12+Lingo2.
The moral of the story- I don't listen to the CD5 anymore !
Gregg
Posted on: 29 April 2004 by faz
SB
Can you elaborate on how the Origin Live motor upgrade improved the sound of your SystemdeK? I ask because I own the same tt and have been considering an upgrade for some time.
Have you or rather the tt experienced any speed stability problems with the OL motor?
Does the sound become clearer at the expense of loosing the bottom end?
I'd be really interested to hear your views. Incidentally, have you tried an OL modded RB250? I did and the difference was: bigger soundstage, more detail and more PRAT.
Posted on: 29 April 2004 by SB
I rate the OL kit as incredible value for money.
Firstly I wasn't aware of any speed stability problems. However all the reviews refer to the cogging effect of the AC motor. This will result in an Audio frequency "vibration" at some multiple of the 50Hz mains, not sure what the multiple is as I don't know the details of the old AC motor design.
So I guess moving to DC motor totally eliminates this effect, significantly stabilising the speed.
As for sound
1) much better overall clarity throughout the range
2) extended and deeper bass, so no lack of bottom end
3) bigger sound stage and greater stereo separation.
Another side benefit is the ability to switch between 33 and 45 instead of changing belts. So we are now listening to the singles collections from our youth :-)
I am still with the original Linn arm and this does show some limits of trackability with tricky media. AC/DC's Hells Bells from Back in Black is a really good example.
As for the kit itself. It was a little tricky to fit as the motor is much deeper than the original so I needed to put a cut-out in the base plate to get it to fit (Only a few mm too long but that was enough). Still took less than a couple of hours to get the whole thing up and running.
The other item which works really well is substiting the original felt mat with a Ringmat
Thanks for your views SB.
I'm definitely interested in upgrading my Systemdek now. My reference to the speed instability was meant to be iro the OL motor. There was a posting a while back in which an OL tt kit displayed speed instability problems whenever electrical items in the owners house were switched on or off. However you sound well pleased so I assume you had no problems.
I've never used the ringmat-is it worth the dosh?
Posted on: 30 April 2004 by SB
Hi, No I haven't seen any speed issues with the OL kit. It is through a Russ Andrews power block with a PowerKord feeding it however.
Since the OL upgrade I haven't tried the TT without the ringmat, but it certainly made a significant difference with the old motor
Posted on: 30 April 2004 by domfjbrown
He he - interesting how we all hear things differently, as, while my CD5/FC is good, my Planar3 is still better on about 85% of my vinyl... I have an Ortofon 540/RB300/motor upgrade (so it's essentially a P3), but I also have a Flutterbuster.
The Flutterbuster totally transformed the Rega - loads of deep bass and decent tracking too Smile
__________________________
Don't wanna be cremated or buried in a grave
Just dump me in a plastic bag and leave me on the pavement
A tribute to your modern world, your great society
I'm just another victim of your highrise fantasy!
Posted on: 30 April 2004 by fantasy63
I also have an 18-year-old Systemdek IIXX with a cheap Mission 774 LC arm. I replaced the arm cable with the Extreme Phono Crimson cable (DIN-RCA) and installed a Goldring 1042.
These 2 simple upgrades improved significantly the TT performance, and appeared to be worth the dosh.
Daniele
Posted on: 30 April 2004 by JonR
Domfjbrown,
I too have a P3'd Planar 3 (with RB300 arms/Super Elys MM cart).
What on earth is a 'Flutterbuster' ??
JonR
Posted on: 30 April 2004 by Alco
I recently had a P3/Grado Green in my house, and it was absolutely no comparison to my CDX.
Hell, even my s/h Rotel RT935 tuner sounded way much better than the P3.
(could be the budget-cartridge, I don't know...)
regards,
Alco
Posted on: 30 April 2004 by J.N.
I think this is to some extent; a personal perception issue.
To my ears, my relatively modest LP12 (Ittok/DV10x4) produces music that in some ways eclipses my CDS3.
That vinyl magic is very difficult to quantify.
