CD Cataloguing software
Posted by: calum scott on 05 September 2000
I'm looking for recommendations for software to catalogue my CD and record collection.
My collection isn't that vast but includes classical and rock so something which is flexible would be good.
As someone pointed out on another post recently it's worth having this if only for insurance purposes just in case the unthinkable happens.
Appreciate any help.
Calum
Posted on: 05 September 2000 by Former member
You might want to have a look the following sites
Tapetracker home page
Posted on: 06 September 2000 by Nigel Cavendish
I use a simple excel spreadsheet - one on my pc at work and one on the pc at home. The chance of both places burning down simultaneously are pretty slim.
cheers
Nigel
Posted on: 06 September 2000 by Former member
I use a product called Davilex. It is very comprehensive with more stuff then I will ever use. Cheap at £19.95. The only bummer was putting them all in there to begin with.
http://www.davilex.nl/uk/index.htm
Posted on: 06 September 2000 by Rico
Stone the crows! if it's not the ghost of burger king! Welcome!
Rico - musichead
ricomuzik@hotmail.com
PS - does that get me an 'overuse of exclamations' sanppy?
Posted on: 06 September 2000 by ken c
hi calum,
i use ms access. its fun to use sql to search the database after the hard work of setting it all up in the first place.
enjoy ...
ken
The spreadsheet's simple grid user interface involves less faffing about than any database application I've seen. It's very clean and direct.
Joel
Born to groove
Posted on: 12 September 2000 by Former member
Bekon Idealist works for me. Bekon.com. It's the best flat text database around (maybe). You are not fixed to any record or field format so you fine tune each record as you see fit. It accepts graphics so the album sleeves can be displayed. And it's dead eay to search. No building SQL commands, etc, just type in the search term.
Tom
