Fraim Request
Posted by: woodface on 27 April 2004
Surely there has to be a better way of securing the little plastic cups than the oh so fiddly little sticky tape rings? They are far better at sticking to your fingers than the glass!!! A product at this price should have a more elegant solution.
Posted on: 27 April 2004 by Bosh
Its even more of a pig when you find that you've put them on the wrong side.
I set my shelves to ring ala Mana following forum advice, but then following further advice I did a listening test on 3 and found they all sounded better the other way up
Must Email Richard to see if he can send me some more stickys
Posted on: 27 April 2004 by Geoff P
The stickys are'nt mandatory are they?
As I understand it they are a safety device for the child monsters.(don't see how they are really much use though)
Mine have grown into adult slobs so I did'nt bother to use the stickys.
Now somebody is going to tell me they change the sound for the better.
regards
GEOFF
regards
GEOFF
The Fraim stickys are useful for when the Fraim or shelves gets knocked by dusting, armchairs sliding towards fraim as they are bounced in and out of over several weeks.
My LP12 shelf seems to float very easily across the front 2 ball-bearings pivoting on the rear one.
Posted on: 27 April 2004 by tpc
Hi
Not wishing to interrupt, but I'm thinking of going the Fraim route. Can any of you give me an idea of the benefits you achieved? Not least given the cost.
Many thanks
T
Many thanks
T
Posted on: 27 April 2004 by Thomas K
Yes, and if you turn them over yet again they may ting-a-ling-ring even better than before, depending on the weather and the tide. That was my experience, in any case. I also suspect that it doesn't make that much of a difference on the whole and any perceived "massive improvements" could be down to differences in setting up the actual shelves, contact cleaning (if you power down and unplug), etc. The Fraim sounds fabulous even without the nth degree tweaks.
Thomas
Thomas
Posted on: 27 April 2004 by John3
I once accidentily knocked the glass shelf off the one of the ball bearings and thought the whole fraim was going to come crashing down. I now have a plastic cup over every ball.
Posted on: 27 April 2004 by joe90
I put the sticky on the plastic cup, then placed them on the ball bearing, then put the glass shelf on. I find if you take it slow and go rack-of-the-eye it's a lot easier than using the cutout.
Joe90
Joe90
Posted on: 28 April 2004 by Bosh
Joe90
Its easier if you put the glass shelf on the Fraim the wrong way up, put the sticky on the cup and stick the cup to the glass over the ball bearing and then flip the glass
Posted on: 28 April 2004 by Rick Weldon
if you had a good dealer they would do it for you!!
Posted on: 28 April 2004 by joe90
I agree with Rick.
But Bosh, is there a right way up for Fraim glass? Surely you havin' me on Guv'nor!
Joe90
Joe90
Posted on: 28 April 2004 by Geoff P
Oh no he isn't!
Tou are supposed to tap it in the center with your fingernail, once it is resting on the ball bearings.
Whichever side "rings" the loudest should be selected as the top side.
Trouble is as Thomas comments, if you repeat the test you will probably change your mind each time.
Happy Ting-a-lings
GEOFF
Happy Ting-a-lings
GEOFF
Posted on: 28 April 2004 by timster
Wasn't until the cat jumped on the top shelf that I discovered that's where the rings need to be. Almost knocked the whole bloody lot over without them....
tim
tim
You're serious about right side/wrong side of glass?!?
Man o man have I been left out of the loop!
Joe90
Joe90
Posted on: 29 April 2004 by BigH47
Geoff P do think they sound better as they grow up?
Howard
Howard
Posted on: 29 April 2004 by Bosh
Yes there is a significant difference as reported previously on this Forum
Geoff P: I set mine up to "ring" first time round
When I did a listening comparison I found on the 3 that I tried (LP12/Pre/CDS) it actually sounded better the other way up.
Posted on: 29 April 2004 by Geoff P
Actually no. But I have crap hearing
Maybe i should stop biting my nails!
GEOFF
