DARKNESS EMITTING DIODES
Posted by: Berlin Fritz on 12 September 2004
Couldn't see it myself ?
Posted on: 12 September 2004 by BigH47
Its bad enough with my sons stereo emitting Darkness!
Posted on: 12 September 2004 by J.N.
My Dear Fritz
Has the Naim forum done this terrible thing to you?
Any advice for fellow devotees?
Did you get your shoelaces sorted out?
Posted on: 13 September 2004 by Rasher
LED's use electricity to make light. Solar panels use light to make electricity - therefore absobing light and creating a darkness in its place. Whether it is correct terminology to say that darkness is "emitted" I haven't yet decided.
Posted on: 15 September 2004 by Berlin Fritz
Upon waking this moaning I discovered a melted twix bar between my legs and a half empty/full bottle of Beck's beer under the pillow, has this any meaningfull psychological significance I wonder, or should I just fire the maid ?
Graham George Of Illusionsofgrandeur²
Black Holes are well Dark, so's Dark Energy.
PAINT IT BLack
PAINT IT BLack
Posted on: 15 September 2004 by Rasher
It isn't the maids fault. Much better to use cable ties, squirty can cream and strawberrys.
Mind you....it usually looks so good, I eat it myself.
Sounds like one of Munch's works ?
