Krell,Pass,Levinson Amps with CDX
Posted by: philip rubin on 07 December 2000
By all means keep an open mind, it's your money.
However, you say you've been using Naim gear for years. That being the case I would suggest that you must like what Naim systems do otherwise you'd have changed some time ago. I would advise you to think very carefully before you make a complete change such as this. Go for a dem', use your ears and don't just change because it is different. In the long term you might regret
it. ![]()
Also, I'd expect the CDX to perform better with other Naim equipment than with other brands, but then I would say that 'cos I own an 'all Naim system'. ![]()
Brian
I'm not familiar with the PassLabs kit, but have spent some time listening to Krell.
To my ears there really is no comparison between Naim and Krell, and would happily take a Nait 2 over a KAV-300i.
I'm a little unsure as to why you are thinking about looking elsewhere for your amplification. Are you unhappy with the "Naim Sound" and thinking that going for one of the big american amps will help?
For my money, i would go for the 82 / hicap / 250, as i think that it offers far more musical satisfaction than the Krell kit.
What speakers are you using?
Matt
If you need something worthwhile to compare Naim against, try DNM or Densen.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
You'll have a fast CDX into a rather slow Krell and it's just not a good match. Can't comment about the rest of the American gear, but I assume it's roughly the same.
Personally, the one system that I've heard that was about as involving as low level Naim was a conrad-johnson base preamp and a Premier 11A amp. I also liked the VAC 70 watt amp at Singer in NYC.
If you're contemplating spending Krell/ML money, you can listen to everything, or just buy a NAC52 and a 250!
Also, the Red Rose stuff which is retailed only in NYC is getting a lot of respectable hype, as are SETs. Art Dudley has thrown over Naim for SETs. And Exposure stuff is good. Lots to pick from. Hope you enjoy your search.
Regards.
Phil
Thanks for your reply
Levinson's decidedly better, but way too expensive. My only problem with Levinson is that it is boring. At least it doesn't hurt your ears.
Can't write anything about Pass, but I can say that you may want to consider Spectral if you're going to spend gobs of cash. It's the only American hi-fi brand of electronics I've heard that I like. I've only heard one demo, but was extremely impressed. I can't make specific suggestions as it was beyond my price range. Spectral shares a propensity for "speed" with Naim. It's definitely exciting.
Also consider Sim Audio. It's Canadian, but what's Canada other than a majority owned subsidiary of the USA? After Naim, it's just about my favorite gear. All of the gear is good, the W-5 being a particularly good amp, and the I-5 a killer integrated.
In the end, though, Naim electronics are better than the above mentioned, the Spectral possiblyexcepted.
My advice:
1. Remind yourself of what you want the system to sound like before you start listening to choices. You have owned your Naim system for some years. You may have to "unlearn" a little and take a fresh look at what matters most to you.
2. As you know, Naim gear isn't designed to sound "invisible". So you may find that the CDX will sound best with a Naim backend (by design).
3. Take your time to decide (this related to point 1). You may find the virtues of a new system don't reveal themselves immediately. Take equipment home (if you can) and listen to it with an open mind and open ears!
BAM
Just a note: with a Supercap, you've got lots of upgrade room in the preamp area - about the only thing that won't improve is a 62 or 92.
Good lick!
