Mountain Bike accessories
Posted by: stevie d on 30 April 2004
Hello All
From reading on here I can see that many of you own mountain bikes and take it quite seriously so I was hoping that some of you may know a good internet based accessory company where I can get some new pedals.
Basically I wiped out whilst riding around a dirt track last weekend and as a result of this one on the pedals is ruined so I need to buy a new set. The type I am looking for has grips on both sides and does not come with toe clips (I much prefer pedals without)> I also tend to prefer metal pedals.
I have looked on wiggle but they do not seem to have what I am looking for. My budget would be about £25-30 so I was hoping that some of you would have ideas or recommendations.
Stevie
Posted on: 30 April 2004 by matthewr
Wiggle has every type of pedal I am aware of so I'm not quite sure exactly what you are looking for if you can't find it there.
Matthew
Posted on: 30 April 2004 by Steve G
I use either http://www.chainreactioncycles.com or http://www.wiggle.co.uk/ for nearly on my online cycling purchases.
Chain reaction have a "flat pedals" section and that includes several options in your price range:
Azonic Fusion Mag - £24.99
Club Roost 1D Traction Pedals - £24.99
DMR V8 Grease Port - £21.99
Kore Race Platform Pedal - £24.99
Wellgo V12 Copy - £21.99
I don't use flat pedals so don't use much about them, however DMR seem well regarded.
Posted on: 30 April 2004 by stevie d
Matthew
I agree that wiggle is very good for things like this.
I have actually looked again this morning and found something that I did not see the other day. I have ordered a new set now and they should arrive Tuesday.
Stevie
Posted on: 30 April 2004 by Simon Crosland
Since we're on the subjet of flat pedals, can I ask a side question?
I have a pair of SPD compatible shoes which I no longer use with SPD pedals ... so does anyone know of a cover or blanking plate that I can bolt in place of the cleats to increase the grip area on the bottom of the shoes?
I was thinking of something like this but that's for Look fittings and so obviously won't work.
Simon
Posted on: 30 April 2004 by Mekon
Flat pedal should equal DX clones. The DMR V8s plus a set of Terror Pins would give you epic grip. That said, I use a set of very cheap Wellgos on my Thrillseeker, and they are fine. However, if you like your pedals to run smooth, you might want to splash out on the V12s. I doubt it's worth the extra, it just depends how anal your are.
I run beartraps on my full sus, and occassionally sharpen them up with a file for extra grip. They eat shoes and take lumps out of your leg if you do slip off. I like them, but I would hesitate to recommend them.
Posted on: 01 May 2004 by Simon Crosland
Thanks for the recommendation, I now have some DMR's on order.
Simon
