Pre-amp limiting factor?
Posted by: Ian.B on 15 December 2000
Current system:
Rega Planet
32-5/Hi-Cap/250
Royd Minstrels
The 32-5 is standard i.e. no 72 filters etc. The 250 was recently re-capped.
How far is it worth upgrading the source since I don't plan to upgrade the amp (except maybe the 72 filters option)any further?
I have been advised the pre-amp is the limiting factor and that it is not worth going beyond the CD3.5/5 level unless I upgrade to 102 or 82.
Any advice would be appreciated.
Posted on: 15 December 2000 by Joe Petrik
Ian,
Your 32.5, Hi-Cap, 250 combo is solid amplification, so it'll reveal the shortcomings of your Planet only too well.
I used to run an LP12, Lingo, Ekos, Klyde into exactly the same amplification. As you can tell, I'm a source-firster, so I think your amp is more than good enough to reveal the best source you can buy. If you go with Naim, that means a CDS-II.
The balance guys might be more inclined to say that you're OK up to a CD5 or CDX, but after that you should consider a better preamp like the 102 or 82.
But I think both camps would advise you to get a better CD player as the first step.
Joe
P.S. Even if you stick with your Planet for now, it's worth getting the updated boards for the 32.5 as a low-cost upgrade.
Posted on: 15 December 2000 by Paul B
Ian:
I agree with Joe. Improve your source first.
Paul
Posted on: 15 December 2000 by Former member
May I suggest you consider an equiptment support which would make a worth while improvement to all your existing system rather than just part of your system and may well work out as a cheaper option than source first.
Merry Christmas Happy New Year.
hooch
Posted on: 15 December 2000 by Vik
I heard the Planet for a bit against the NAT-03. I was surprised that a tuner could outperform a CD player. Not that the Planet was bad. I hope that in some back-handed way this helps.
Also, I feel that a CD2 would make an excellent choice.
Posted on: 15 December 2000 by Ian.B
the 03 as I'm looking at adding a tuner also. I guess the sonic differences between say the Rega Radio/03/02 are of the same magnitude as Planet/cd3.5/cd2.
Ian
Nice pose in the latest Naim newsletter, Vik.
James
Resistance is Futile
