Rega P25
Posted by: Le Chef on 25 November 2000
What are the good choice for cartridges to go with this deck? Back end is all Naim. Music is mostly jazz. Any good sugestions?
Posted on: 25 November 2000 by mr saucisson
Chef! Just noticed that this is about to become the second post of yours I've replied to tonight!
Can you use a MC cart? If so, it goes without saying that these would be preferable. However, if you are in a similar position to me, RF interference made this a no go. As a consequence, I went for a Super Elys, which is OK as a stop gap - until I move again. Whilst not ideal, I do think that it does offer better VFM than any of the other Rega carts, all of which rather disappoint at the price.
If an MC is on the cards, I would suggest that you lash out on the extra for an MC30 Supreme - a quantum leap, indeed a cartridge which the P25 is good enough allow it to shine through.
What do you think of the P25 by the way? it seemed to get a rather muted reception, both on this forum and elsewhere, but I think that it is a cracker. Any plans for the P9 upgrade?
Ben
Posted on: 25 November 2000 by Former member
If you want a great sounding, cheap MC for a Rega, try a Denon DL110.
The Denon is a high output MC that sounds WAY better than you'd expect for £70.
I used one on a P3 for 2 years and would say that it kills a standard Elys and Linn K9.
Rob.
have used a p25 for almost a year now and went thru/indulged in 4 cartridges.
firstly, i think the P25 is a little bit soft and just a tiny bit thin/light, i have it on BASE stand/platform, and it might benefit by being on something like glass. the $200 Projekt 1 i used to have, with cheap goldring/ortofon had more OOMPH. does anyone have views on location of the turntable?
bought it with a rega exact, which was ok, then a grado platinum, which needed a spacer, but was also okay and then bought a dynavector 10x4, which was even better(real cymbals), now i have a te kaitora, almost top of the line dynavector, with s-boards. the first three were mm's. basically the turntable works very well with all of them. i was just looking for something probably the table can't achieve...
i've never really achieved oozy, liquid sound from any of the above cartidges, compared to the cheap Projekt. Anyway, the Linn/Ekos/geddon/transfiguration spirit at the naim dealer here doesn't sound as liquid as my Projekt, so maybe it's a factor of modern/precision turntables, sounding anal and cold---ie. CD like? i've read that many places before, people referring to the P225 as CD-like. maybe the old projekt wowed and fluttered and resonated so much, i mistook it for warmth?
who cares. try the above cartridges. the Dynavector 10x4 is high output MC you can use with MM boards and is better and cheaper in my view, than both the rEga exact and grado.
rgds
shahreza
Posted on: 25 November 2000 by Le Chef
I'm in that dilema of being (maybe) jaded with with my LP12/Lingo/Aro/Troika...I have never quite gotten used to the suspended deck - it always feels like I'm standing on the deck of a ship trying to put the arm down (failed Aromatic as well) while the LP12 is mounted on ballons. I used to have a P3 and have a hankering to go back to something solid. Sounds like heresy I'm sure, but I spent more time listening to vinyl on the P3 than I do on the LP12. The dealer has a P25 available for a trade in my favor, or I could go to the P9. I'm also in "downsizing" mode trading out my old style 72 + 4-pack active SBL system (which in a high-rise sounds like you're standing next to a power station with all the rfi, etc) I keep thinking simple thoughts, like a 102/250 + SBL's or maybe a 112/150 combo...
Thoughts?
Any reasonably well set up LP12 should wipe the floor with a P25.
I had a P25 for a while, which I bought for a second system, and found it so thin, light and mechanical sounding that I ended up selling it. Now I use my old Project 6 in the second system, which is much better, even with its rickety arm. I agree with Shahreza's comment that the Project turntables are very good for the money, and are capable of producing an extremely good performance, with a very liquid, solid sound.
However, neither the P3, P25 or Project 6 turntables I've owned sound anywhere near as rich, dynamic, liquid, detailed and rhythmic, as my LP12/Cirkus/Ekos/Armageddon/Ortofon Rohmann.
Ross
Posted on: 26 November 2000 by Former member
Hi Chef,
You might want to consider the Dynavector 10 X 4 mk2 with the P25. I had one mounted on the P25/RB600 combo and it worked fine without the need for any VTA adjustment. Good dynamics, a fine tracker, and not too expensive. In case you have not seen it, there was a review in Listener Magazine a while back that is worth hunting up.
Best,
Clif
Posted on: 27 November 2000 by Former member
What about the Goldring Elite? - it uses the
N boards and is about the same price as an
Exact.
Posted on: 27 November 2000 by Bob Edwards
Le Chef--
Since you are in Chicago, you are doubly blessed ! There is a great Naim store in Chicago (I know you already know them, but ) called Pro Musica. Work with them--they are a class operation. Secondly, Chicago is home to NANA--and I know they would help you if asked. Take advantage of your resources and try a couple different combinations and see what you think.
Bob
PS--Check your email !
PPS--I agree with Ross--an LP12 properly set up will wipe the floor with a P25. There are also those who feel an LP12 does the same even to the P9 !
ˇ
Posted on: 27 November 2000 by Laxton
Clif,
Do you have the link to the review on the 10x4mk2? I can't seem to find the site to the magazine. Thank you.
Laxton
That's right and here is a rare picture of two individuals who are part of the population that feels this way.
"Hey dude, check out those Cerwin Vegas!"
Posted on: 28 November 2000 by Rico
What about the Goldring Elite? - it uses the N boards and is about the same price as an
Exact.
Is that the high-output version? There's also (more common) Elite with "low" output which runs on S boards.
Rico - musichead
Posted on: 03 December 2000 by Former member
Hi Laxton,
The very favorable review of the Dynavector 10 X 4 mk2 appeared in the Spring 99 (vol. 5 #2) issue of Listener Magazine. I'm not aware of any web links to this review.
Best,
Clif
Posted on: 04 December 2000 by Frank Abela
Chef
If you're heavily into downsizing, then the P25 is a worthy contender. I think the P25 is fabulous value for money. It doesn't have the LP12's warm bass colouration and it's easy to set and forget. I disagree with Ross (as I always do) about the quality of this deck and I can only surmise that we look at things with a different perspective. In terms of timing, the P25 is almost up there with the Linn! What you get is a much smaller picture, however. The P25 doesn't have the resolution or depth of the Linn.
The P9 is a much more grown-up deck. There are some who prefer its astounding timing, lack of bass colouration and pace, as well as the fact that it's set-and-forget, requires little to no maintenance, and is beautifully made. On the downside, it still doesn't have quite the same scale, portraying a smaller (perfectly formed) picture, and it has a tendency to a little brightness if unsuitably matched. It is a *very* good machine - make no mistake.
As to cartridges, I always recommend the Dynavectors. The 10x4 is an excellent MM offering. If you wish to stay with MM for RFI reasons, there is always the 20XH or the XX-1H. If you don't have RFI problems, then the 20XL, 17D2 (excellent value for money, though Ross disagrees) and the rest all make sense in either deck, though placing a Te Kaitora in a P25 might be a tad much!:) You wouldn't be maximising the Te Kaitora's performance in that scenario.
In my experience, the Dynavectors require a 2mm spacer under the arm for good VTA.
Other options are the Ortofon MC25FL which times like no other for the money, though it has a bit of a harsh treble. I do not like the MC30. Although it has a lovely mid-range, I find it hasn't got any timing to speak of, so I find it boring in the extreme. The MC2000 is a really good cartridge too but that might be a little expensive? Works well in Regas...
I don't go a bundle on Rega's own cartridges since I find their treble to be too busy.
Shahreza - I think the Base might be causing the soft/thinness. Try replacing the isolation platform with something solid (solid MDF or a large tile will do) just to see if the suspension in the rack is causing the problem. We steer clear of the Base platforms for Regas. You could try glass but I'm not so keen since most Regas are already a little bright in balance, most of the time, but even glass is preferable to the isolation platform. This is pretty unusual since the Base stuff usually works well with turntables. If you find the glass/tile/MDF is better, then you could try removing the little rubber feet from under one platform and see what effect that has (I haven't tried it).
I have tried the Projects and I found them quite boring. Yes, they were smooth and silky, but that's not for much other than pleasant background occasions in my book. At least the Regas have pace and excitement.
Chef - In terms of the other question of downsizing, I was discussing the 112 with one of the Naim people yesterday. Now you must appreciate that this was during a Christmas bash and everythign was a little foggy at the time, but this gentleman did say that the 112 is quite superior to the 72, though probably not on a par with the 102.
Personally, if you wish to downsize, then I'd just stick with the 72 and throw in a 180 or 250 instead of the 4-pack. But you WILL lose in terms of resolution, speed and timing. Alternatively, for a really simple, but very effective change, you could swap all your 'amp' for an 82/180. Nice and simple - 2 boxes!
But the 82/180 is a real peach for the money. You'll lose out in terms of scale and drive, but you'll gain many benefits in terms of resolution and dynamics so it's swings and roundabouts really, but it will offer you something quite different from what you've got without being too much of a shock. We've had loads of people who absolutely fell in love with that amp since it has so many of the best Naim trademarks.
I hope this helps (unlikely, I know...)
Frank.
Posted on: 04 December 2000 by Le Chef
This a tough decision to "downsize" based on hearing that is losing top frequencies. All of your advice leads me to 2 alternative routes:
a)Keep the LP12 (but trade the ARO for an Ekos unless the Aromatic can be fixed), trade the 4-pack amp, buy an 82/250, keep the SBL's, add a CDX, add a NAT02
b) Trade the LP12, buy a P25, trade the amps, buy a 112/150/Flatcap2, keep SBL's, buy CD5, buy NAT05
My dealer doesn't have the full Series 5 stuff yet but I'm sure he will let me spend extended listening time to both setups.
Thanks again for all your advice
Le Chef
Posted on: 18 December 2000 by Former member
hi frank
i just got back home and playing the p25 again, it's not 'light', but thin. the ideal sound would be a bit more 'full'. does this make sense?
(oops, does that mean i'm a round earther?)
NAAH!! i meant full-toned, without being boomy. is this possible with a P25--or Rega in general?
havent fiddled with the platforms yet.
regards
shahreza
Posted on: 18 December 2000 by Dev B
Just thought I would add that a Well Tempered makes any LP12 or Rega P9 I have owned/heard sound broken.
Dev
Posted on: 18 December 2000 by Bob Edwards
Dev--
My experience is the opposite--a maxed LP12 (or even a Rega P3) makes the WTs I have heard sound dull, lifeless, and boring.
A case of horses for courses, I think.
Bob @ Qwest
Posted on: 18 December 2000 by Rob Doorack
Actually it's a high output moving coil design.
