Nac 102 noise
Posted by: Bernard Paquet on 27 November 2000
Bernard Paquet
I used to get a faint thuding sound from my 102 when quickly tapping the volume control, this went away completly when I got a NAPSC. Your situation with a NAPSC and hicap sounds odd.
Kevin.
The only other possibility is a DC level on the pot being passed through to the subsequent amplifier stages (due to a leaky coupling capacitor?).
If the first tip above doesn't help, go back to your dealer / return to Naim for assistance.
Andy.
Andrew L. Weekes
alweekes@audiophile.com
This happens on mine also. It's a kind of "Chuff,chuff,chuff" sound. My question to you is what speakers are you using ?
I did not hear this sound until I bought my Kelly KT3's. They are much more sensitive(95db) than my old Missions(89db) and this seems to be why I hear the noise. It only happens when you change the volume from the remote so I assume it's interference from the motor.
Darren Miller
I try last evening the trick that Andrew recomend but nothing change.
Maybe it's a question of setup. Or a bad ground. I don't have naim cd player nor a turntable so i'm not sure the kit is perfectly grounded. ![]()
Bernard Paquet
Enfin, un probleme de moins.
Bernard Paquet
My SBL's are 88db, which isnt massively sensitive, but if you have a speaker in the low 90's you'll certainly get some hiss.
I get some white noise on my speakers (BW N804) which are not especially sensitive, I think this could in part be to main noise, my system is on a ring with lots of other stuuf on it (no choice), but the system is in my bedroom and the noise is much too quiet to keep me awake. So normal.
Haven't noticed any noise when changing volume (except the ones that you expect) on my NAP102 with no NAPSC (next move I suspect).
Matthew
