Best Value Record Cleaner
Posted by: SteveH on 17 November 2004
Any advice about which record cleaning machine I should purchase?
Is the Moth kit at around £250 good value or do I need to spend more to get something that really does the job well?
I'm not looking to clean more than 50 records per year I guess, depends on how many I find in second hand shops.
Steve
Posted on: 18 November 2004 by Nick_S
My goodness Tom, what have you done to your Linn LP12...
Nick
Posted on: 18 November 2004 by Stephen Bennett
There are quite a few threads about this on the forum. I use the Moth. Works perfectly - but it is loud!
Stephen
Posted on: 18 November 2004 by Geoff P
Tom what have biscuits got to do with record cleaning?
"Just trying to make a NAIM for myself"
Posted on: 18 November 2004 by starbuck
google 'diy record cleaning machine' and follow the instructions. Paint pads can be used as an alternative to the (relatively) expensive VPI brush.
Have fun,
Chris.
Posted on: 18 November 2004 by The mole man
Forget it, 50 records are not enough to warrant buying a RCM, IMHO. You'd do better to find a local second hand record shop or hi-fi dealer who offers a record cleaning service. The going rate is around £1 per disc (including static free inner sleeve).
Mole Man
Posted on: 18 November 2004 by BigH47
Fine if you have A) a local record dealer. and B) they have a record cleaner. Short of going to London Berwick Street I don't know of a closer place that cleans your records.
Howard
