Isobarik (my similar problem)
Posted by: mark dunsford on 01 September 2000
I have some oldish Isobariks but suffer from excess loose lower bass which tends to drown out the midrange. Ideally I'd like more mid range projection as well. I have considered Mana stands and the Torlyte Russ Andrews stands but both are very expensive, does anyone have experience of either of these?. The rest of my system is Sondek LP12 on Mana Frame, Ittok, Troika, Linn Kairn, Naim 250 (yes this combo does work beautifully- more lively than NAP82) and hybrid solid core/NAC05 speaker wires. Isobariks are on their own stands on a suspended woodern floor. Thanks for any advice!
