My Nat is going disco!!!
Posted by: Bas V on 30 November 2000
Hi!
There's something strange with my NAT03. At night the displays goes along with the beat of the music. It lightens up with the beat of a song, very strange... It is connected to the cable.
Does anybody know about this effect?
Regards, Bas
Posted on: 01 December 2000 by Adrian F.
...don't place it on your subwoofer!!
:D
happy listening
Adrian
Posted on: 01 December 2000 by Bas V
But Adrian, read my profile and you'll know better than that ;-)
Posted on: 01 December 2000 by Rico
Bas, as the display also indicates signal strength, is it possible your signal is a little low? Only modulated by the heavier parts of the music? <slaps head - or am I getting confused with AM?>.
Is this the same for all stations, or just one?
Rico - musichead
Well Rico, I have omly listened to one station so far, but I may have solved the problem. I twisted the knob a little and it seams to have disappeared. Strange or not?
Posted on: 04 December 2000 by Adrian F.
O.K. Bas V, I'll take that one back.
You can add some FEP's to your account!
happy listening
Adrian
