Microsoft Antispyware
Posted by: Naheed on 10 January 2005
Just loaded the beta version, i normally run spybot, adaware, etc... yet even after that the Microsoft version found 53 !!!!!!!!!!!!! others leaches, and a hijack attempt
Maybe worth checking out while its free on the beta version
MS Anti Spyware Download page
naheed. . .
naheed. . .
Posted on: 10 January 2005 by Adam Meredith
Interesting - neat little programme - detected 0 threats. I suspect that Anti-Spyware is good to have but a good firewall and Internet Explorer settings on "tight as duck's arse" seem to be preventative.
Posted on: 10 January 2005 by Mick P
Chaps
Just go through the security section of this lot.
http://forums.techguy.org/
Read how I got infected in the first place.
You will be bomb proof.
Mick
Mick
Posted on: 10 January 2005 by Roy T
I gave it a try and it found one minor problem SearchSquire.
A couple of moans though about the installation.
I allowed it to check my copy of windows and it downloaded and run an app that gave me a code to paste into a box on another part of the form . . odd indeed, a crap UI.
It then asked for my 25 digit activation code??, now me having an oem copy with just a rescue disk and a couple of disks from Toshiba could not supply the string so I then aborted and went for an unvalidated install.
A reasonable effort spoilt by a crap UI and an odd validation procedure but why do they have to buy in something to hunt for spyware and why can't they build it them selves?
Posted on: 12 January 2005 by Naheed
I have a software and hardware firewall, but unfortunately where I download music from requires either Gain or Netpumper, which comes with all the ad's and pop-ups., but it seems the usual spy software did not detect these, even with he latest greatest updates.
at the end of the day, i guess its just one more thing Microsoft can try and monopolise...
naheed. . .
naheed. . .
Posted on: 12 January 2005 by Paul Hutchings
There's a certain irony to this isn't there.. Microsoft buy out a spyware company so that users can fix problems, 99.9% of which originate from poor security in other Microsoft Products
That said, this does look a decent product, much as people might bash MS, if they promote a product like this, people will be far more aware of the problem, and likely to address it than if they have to turn to third-party programs that they've never heard of.
It's also quite nice from my POV as a network administrator - I've not looked at it in great depth yet but I'm pretty sure it can be automagically rolled out to desktops, and scheduled to update and run at a set time each day/week.
Paul
Paul
