iTunes and Naim
Posted by: Dobbin on 04 August 2004
This may be a really daft question....and disregarding quality etc etc....BUT is it possible to link a windoze xp pc's iTunes to my Naim kit???
Posted on: 04 August 2004 by Misguided Fool
Should be straight forward:
LINE OUT on the PC to an input on your pre-amp.
Hope that helps.
Mark
Mark ;0)
Posted on: 04 August 2004 by Martin Hull
If you have a wireless network you could also use a Squeezebox or an Apple Airport Express which is handy if your PC is not in the same room as the your Naim.
Martin
Posted on: 04 August 2004 by Simon Perry
I am considering this. Martin - is there a particular product that you would recommend in order to transmit the data from the PC to the Airport Express box?
Simon
Simon,
I would have thought any 801.11b or 801.11g PC card would do it but I am all Mac at home so I don't know any models to recommend.
Martin
