Can anybody suggest a laptop PC available second hand that'll take a full length PCI card (like, if anybody has a Toshiba 3200SX to sell). Doesn't need to be particularly recent or powerful as it'll just be running MLSSA under DOS for loudspeaker development.
Phil
Posted on: 13 May 2004 by Eddie Pugh
Phil
I had an HP Omnibook 5700ctx a while back and the base station that it docked into could take one or two full length pci cards. I don't know of any laptop proper that will take a full size pci.
If you can find the matching base docking station (I think I threw mine) I still have the Omnibook if your interested and it works just fine Pentium 166 64Mb RAM Hard Disk to taste
eddie
Posted on: 14 May 2004 by Phil Ward
Thanks Eddie,
I may take you up on that.
Phil
