Amazing new Discovery (but how)
Posted by: garyi on 25 November 2004
Me and the better half got into quite a heated discussion on the weekend regarding burnt CDs.
Some work we had been doing in photoshop had been burnt to CD in toast on my mac.
Sheila bought a CD home from work which she claimed contained new data burnt at work, the self same CD as burnt at home.
Thing is these disks I have here are CDrs they are not CDrw.
Well anyways the disk she bought home only showed the original data that had been burnt on the mac, so rather smugly I exclaimed that I was correct a CDr was burn once only jobs a good'n etc etc.
Well she stormed back off to work to check the disk and shure enough as well as the data burnt at home on the mac was her data burnt back on to the same disk from work.
Tonight in experimental mode I burnt a single image to disk in 'session mode' in toast.
The disk burnt and then verified. and as usual asked if I wanted to eject the disk or mount it. I ejected then put the disk back in, as expected it mounted on the desktop with the single image.
I then put another picture into toast and clicked burn again.
And what do you know, it burnt that bloody image onto the disk no problem, apart from the startling and useful discovery it ultimately means I am wrong!
But what the hell is going on, I was always bought up to to believe that a CDr can only be committed to burn the once, once done that was your lot.
As I understood it the software burnt a track at the beginning of the CD to establish what CD it was, how much memory was used etc etc, how can this be abused, i.e presumably that first image was burnt and then the next 'session' must begin after the last one on the CD.
The mac picks it up as individual CDs, so I had two CDs mounted on the desktop, however it was unable to read further 'sessions' to disk done from a PC.
Confused? You better believe it.
