NAC 82 Powered
Posted by: Naheed on 27 October 2000
Alright then which is better:
NAC102/napsc/Supercap or NAC82/napsc/2* Hicaps
This would be for a cdx/xps...
naheed...
Posted on: 27 October 2000 by Rico
Naheed
You really need to dem, and don't eliminate CDSII until you've compared it through Preamps in your price range, as well as a reference (52/SCap). If you're not moving up a CDX, you can avoid the CDX step by going straight to CDSII.
Once you've decided on your source, fit your budget around the rest of what you have to buy. You appear to have made a number of back-end changes which have imbalanced your system, you've realised that a source improvement is necessary, but are avoiding clear evaluation. What have you demmed and heard so far?
I would predict a CDSII into an 82 naked on 140 would provide a whole lot of music... re-jig the system from there.
Good luck.
Rico - musichead
Posted on: 27 October 2000 by Naheed
Rico, i have already demo'd a cds2/82/hicap/180/sbls, which sounded worse that what i have !!! (bad room/dealer)...
This time a friend is helping with the dealer, but i want something to keep me happy for a while...
naheed...
Posted on: 27 October 2000 by Phil Barry
Personally, I've done two quick comparisons between 102/s'cap and 82/1 X hicap - the 102 was more impressive the first time, but it really seemed like 6 of one and half dozen of another.
Now, the CDS2 is a revelation. If you do a lot of CD spinning, the comparison should be:
cdx/xps 102/s'cap
cdx/xps 82/2 X hicap
cds2/xps 102/hicap, etc.
Listen to Rico. Listen to me. Listen to the CDS2.
Phil
The road less travelled. Have you then eliminated the CDSII and selected CDX/XPS on the strength of a flawed dem, or is there something you're not telling us here? And why use passive SBL's in a dem, when in fact you run active? Your focus is to end you uprgrade loop... select carefully with your ears.
I suggest you use a reference system, and work from that as a baseline. You're starting to head towards CDSII/52 territory, so it might make sense to start there, making substitutions to arrive at your best result for your budget. However, an excellent dealer is first required. And don't forget to buy from them once they've spent the time on you!
Have you listened to the 'unofficial phase 1' Naim system: CDX/102/140/ + good circa £500 speakers, carefully set up on good stands at a fine dealers (such as Audio Counsel)? You might well be surprised.
Rico - musichead
I have'nt eliminated the cds2, i just feel and some have mentioned that the cds2 really comes into it own with the 52...
The cdx/xps/82 selection is due to what i thought was a better balanced system...
The demo was'nt active as the dealer could'nt be arsed - but it will be this time.
Rico, I like the cds2/52 backward approach, but i'm scared i will start 'twitching' too early for it... (i want this upgrade to last a while)...
I have a few options so i'll wait for my demo...
naheed...
Errr... actually, everything comes into its own with the 52.
I've heard CDSII in many systems, through 102(naked and 1 hicap), and 82 (+1 hicap), and 52. There's no mistaking you're listening to the magic of a CDSII through any of these preamps.
Make the right choice and you should not be twitching for the next upgrade; instead you'll just be able to enjoy the music.
Rico - musichead
[This message was edited by Rico on FRIDAY 27 October 2000 at 16:23.]
Posted on: 27 October 2000 by Mike Harris
Hi Naheed,
Give me a shout(or mail) I have spare 82, Hicap and Supercap you can borrow.
With your Hicap you can try *all* the combinations of 82, at home, in your rig...
styl
mikeh
Posted on: 27 October 2000 by David Hobbs-Mallyon
Naheed,
I think your choice will depend on where you intend to end up. If you think that CDSII and 52 are likely in the medium term, I would go for the CDSII, and upgrade to Supercap and 52 when funds allow. Otherwise, like me, you will be losing alot of money, by trading in your 82 for a 52 at a later date.
David.........waiting for the 52
Posted on: 27 October 2000 by John
I don't understand the promotion on the CDSII. I recently had one for 3 weeks and compared it to the CDX/XPS on Mana. In the end the CDSII was better but only marginally. I have never heard a 52 and my bet is the CDSII becomes more important with the 52 and if you go active.
My system is an 82super,135's, SBL's. I would go for the balance of the CDX/XPS, 82, Super (if possible). I think the CDSII and 52 go together.
John
Posted on: 28 October 2000 by Naheed
Excellent feedback, the demo looks set for next saturday (just need to convince a friend to buy some of my left overs)...
Mike, if the dem does'nt go to well i may take you up on your VERY kind offer.
However, Dave/John you've said what i have been thinking all along, i don't what the losses involved in upgrading to the cds/52, and the cds2 really kicks arse once in a 52/active setup...
naheed...
Posted on: 28 October 2000 by Bob Edwards
Naheed--
It was some time ago but I did have a chance to compare the CDS2 and CDX/XPS through a Nait 3. Put simply, the superiority of the CDS2 was instantly and easily heard vs the CDX/XPS, thus verifying (for me) how critical the source is. This superiority has held up no matter what amplification is used--even using a Linn Kolektor/LK85 you could hear how much better the CDS2 is. In your position I would go to the CDS2 and then change preamps when possible.
Bob
PS--I would take an 82 with 2 (or even 1) Hicaps over a 102/Supercap.˙
[This message was edited by Bob Edwards on SATURDAY 28 October 2000 at 17:42.]
