Any one got a kameleon remote?
Posted by: garyi on 02 May 2004
Mine has just thrown a wobbly, the screen keeps flashing on and off with all the buttons lit up. I have removed the batteries and replaced but still the same problem. The remote is un-usable.
Any ideas?
Posted on: 02 May 2004 by Former member
I did have one, but I put it down on the sofa, and now I can't find it at all.
Posted on: 03 May 2004 by hicapman
Hi Garyi,
I have a kameleon and it tends to play up when the batteries are running low (they just don't stop working) they are not known for longevity with batteries.I try to keep a spare set all the time.
Posted on: 03 May 2004 by Former member
gary,
mine does this when the batteries are low. you say you removed and replaced them , was this with new ones or with the ones you took out? if it was new ones then i'm stumped...
cheers
julian
Posted on: 03 May 2004 by TomK
Mine does exactly this when the batteries are about to expire, which happens with a depressing regularity. I'd try another change of batteries, reseating everything, etc.
