Admin.
Posted by: Fisbey on 03 September 2004
May I draw your attention to a post that contains (in my opinion) a somewhat tasteless enclosure - the post in entitled 'Cats are a pest at best' - it is also my understanding that the enclosure was banned in this country by the advertising standards people.
Thanks.
Thanks.
Posted on: 03 September 2004 by Basil
Seconded.
Posted on: 03 September 2004 by Brian OReilly
Thanks FISBEY, I would have missed that otherwise !
Really funny !LMAO
Really funny !LMAO
Posted on: 03 September 2004 by greeny
yeah cheers FISBEY, that's hilarious
Posted on: 03 September 2004 by TomK
Thanks Fisbey. I hadn't bothered following that link before. It's a cracker. Now if it's guaranteed to do this I'm having one.
Posted on: 03 September 2004 by Matt Gear
I'm with Fisbey. Cat having it's head cut off... Hilarious?
Matt
Matt
Posted on: 03 September 2004 by seagull
Fisbey,
Your post seems to have had the opposite effect to the one you wanted. (i.e. prompted people to look at the offending thread.)
If you wish to report a thread that you consider to be in bad taste to the administrators, click on the warning triangle on the bottom right hand side of the post.
Posted on: 03 September 2004 by HTK
Yes it is tasteless and cruel. But so is over 50% of the content of the Padded Cell. Swings and roundabouts.
Harry
Harry
Posted on: 03 September 2004 by JonR
But everything in Hifi Corner is pucka, innit chaps?
Fortunately the limitations of my work PC's software prevented me from seeing the subject of Fisbey's post, but I'm afraid to say that as Seagull said it had the opposite effect to that intended, as these things often do.
JonR
My dog loved it.
Harry
Harry
Dead Parrot.... Hilarious?, Well yes actually
What's the standard defense of the tasteless and revolting? 'Where's your sense of humour?' is, I believe the accepted Padded Cell position.
Harry
Harry
Gizmogirl,
Never, ever have recourse to the words of Michael Winner, immortal or otherwise, under any circumstances!
[Cue sense of humour bypass
Nice to meet you and John the other night BTW.
JonR
JonR
Yes I am fine now, thanks.
Scary thing is he doesn't live very far away from me so if I avoid the bus which terminates in his neck of the woods I reckon my chances of bumping into him again are significantly reduced.
Looking back, though, I think the biggest mistake I made was letting him scare me. Then again I s'pose it's easy to be wise after the event....
See you again at the Heathrow show, maybe?
JonR [cue SoH return, IMHO anyway
