Price for Naxo 2/4?
Posted by: Anders on 18 August 2000
1. What would be a resonable price for a Naxo 2/4 (i.e. not Snaxo 2/4) with the new cosmetics and in very good condition?
2. Have anyone tried them "untweaked", i.e. in their original settings for IBL/SBL, with Kan/Kan IIs? Do one need to adjust setting in order for the Naxo 2/4 to work well with Kan/Kan IIs? Comments?
Anders
Having got the Naxo I've been investigating whether it'll work with my mk1 Kans and apparantly the SBL Naxo is fine, the kans and SBLs use the same tweeter and approx the same x-over point. Apparently JV reckoned that the slope rather than the actual crossover point is the crucial bit. There was a bit of raving on the old forum about how stunning active kans are so I'm on the lookout for a pair of 2nd hand 250 at the moment...
close run thing between Kans & IBL's.
Bob
However, I'm told that the later NAXOs are considerably better than the early ones, so maybe not quite so cheap. In this case, though, I think I'd hold out for a SNAXO.
Refer to the revision lists on the main site for details of when the SNAXO replaced the NAXO.
cheers, Martin.
