PC HELL
Posted by: AL4N on 13 July 2004
Hell may be a bit strong,but it won't turn off.When i click start--turn off or restart,it just goes to the desk top,also after i've logged on when i click favourites and then select a site,it tells me that the page i want is not available off-line,and gives me the choice to "work off-line "or "connect"i have to click connect to view pages.Any help would be marvelous.
Posted on: 13 July 2004 by BigH47
Push and hold the power button in <5sec. This should switch the whole thing off. Then power up as normal, it should have reset every thing back to normal.
Posted on: 13 July 2004 by AL4N
thank you BIGH47,it seems to have done the tric Smile
now all i need to find out why for the first 5 mins or so after i log on,i get pop up after pop up,while these things are doing their worst,i can't do anything. Frown
Have you got anti-virus s/w installed? If not goto:-
Scan
Howard
Posted on: 13 July 2004 by Roy T
AL4N,
it maybe that you have something nasty lodged in your browser and this has the run of the machine and won;'t relinquish control until it has had its way with your surfing. Not nice, not nice at all. I fear you might need the services of tools like spybot and ad-aware to remove this pest from your machine. Do you have any spyware / malware killing tools you could now run?
Roy
Posted on: 13 July 2004 by bjorne
www.panicware.com A good and free popupstopper, the free version is a bit difficult to find but it's there
i have just ran AD-WARE 6.0,i hope it helps.I think i had to delete norton when i installed broadband,(it would not log on with norton installed)so i suppose that could be the problem.
