Posting Images?
Posted by: Jeb on 13 November 2000
Can anyone see this image?
Posted on: 13 November 2000 by Former member
I like the green plug!
Less keen on the paint colour !
Jonathan
But what's the unit below the rega? You don't place a HiCap right on the floor, do you?
Posted on: 13 November 2000 by Jeb
That is my Hi Cap - where do you think it should go?
Well buying another stand might help but I don't think we need to go to that discussion. However you could do a lot worse than put it on Vuk's ball/nut/ball supported MDF. That will isolate it from the floor & will only cost pence.
Tom
... was how to include images above the 40 k limit (or whatever size it actually is), right?
Posted on: 13 November 2000 by Ron Toolsie
"That is my Hi Cap - where do you think it should go? "
Off the floor, maybe on a cross board placed between the bottom braces of the stand that holds the turntable. Also, you really must migrate to the now-not-so-new Black Snaics. They do make a world of difference
Ron
Dum spiro audio
Dum audio vivo
http://homepages.go.com/~rontoolsie/index1.html
