SBL on suspended wooden floor
Posted by: Martin C on 28 April 2004
Hi there,
My SBL are currently stand on the suspended wooden floor with TOUC spike discs. (similar to Fraim Chips, not cheap & made of special metal, but well, compare to Fraim chip? I think they are better, as they have the angle and there is pnly one point for the spike, not lkie the chips, which the spike can move around.)
I am think about to get 2 marbles and place the SBL on them.
I am sure some of you have done some experiments on that, what is the outcome?
One more point, what should I put underneath the marbles to keep them still and not scratching the wooden floor?
Martin
Posted on: 28 April 2004 by joe90
Marbles? U mean slabs of marble as opposed to the marbles that kids play with?
I would have thought silly putty/blu tack is the stuff to use to secure things to wooden floors without damage...
Joe90
Posted on: 28 April 2004 by Martin C
Yes, of course the slabs of marble.
Posted on: 28 April 2004 by J.N.
MartinGet a couple of ordinary concrete slabs to try it. They are normally an excellent cheap solution at around £1 each.
I use a a pair under my Intro 2's on a suspended floor. Works well, and sounds a lot better that spiked into the wooden floor.
I guess big lumps of blu-tack will squash down and protect your floor.
I'm not a fan of slabs of anything under speakers.
Personally I'm enamoured with Philips head screws into wood then sit the speaker on them.
Sounds really good and is too cheap!
Just gotta get it round the goalkeeper/accountant/whatever you want to call her.
Just remember boys, IT'S YOUR FLOOR TOO!
Remember the Beastie Boys: you gotta FIGHT for your RIGHT to party!!
Don't be a sissy boy nancy wife-slapped chook.
Joe90
Posted on: 28 April 2004 by Paul B
I thought Mana SB1's were the best solution for this situation? I've never used them but I had that impression. Am I wrong?
Paul
Posted on: 29 April 2004 by andy c
I used Mana sb1's (still do) at my previous house to cure a reasonance problem re a suspended wooden floor.
I recently tried taking them out of the loop at my present house, which has a concrete floor, and put them straight back again.
andy c!
Posted on: 29 April 2004 by Martin C
Hi there,
Thanks for all the advices, I think i will get a few granite slabs (at least look better and no complain for the missus!).
Actually I have a pair od mana soundbases, don't like it, I think the bass was lighter than without them. The presentation is totally different. I reckon without them, the sound is more natural and open. So I put them for my intro as rear speakers, I need something to raise for a few inches anyway.
Will go to the tile shop this weekend. To try on the Fraims would be also a good idea.
Graham, did you just use the granite slabs just under the fraim to see the difference? Not mixed the effect under the speakers.
cheers
Martin
Posted on: 29 April 2004 by John3
How about using felt protector pads under the granite slabs? This would also enable the whole setup to be slid around the floor to get the best speaker positioning whilst still being a rigid setup.
Posted on: 29 April 2004 by garyi
Ghunter, you been on that Bid Up channel?
Posted on: 29 April 2004 by J.N.
Hi Ghunter
Have you tried toeing the SBL's in a bit?
Hi Ghunter,
Nice pics, So your SBL are sitting directly on the granite slabs at the moment.Will get the granite for the fraims as well.
cheers
Martin
