Prime Number Question
Posted by: Tim Danaher on 18 November 2004
Am bit thick, sir, so this one's been puzzling me:
A prime number is defined as any number divisible only by itself and 1
So why isn't 1 a prime number? It fits the description perfectly, but all the lists of primes that I've seen start with 2. Even in 'Contact' the prime beats sequence starts with 2 beats.
Can anyone explain? I've been meaning to ask this, but I'm a little scared I won't understand the explanation.
Tim
_____________________________
Os nid Campagnolo yw hi, dyw hi ddim yn werth ei marcho...
Tim
Posted on: 18 November 2004 by long-time-dead
"... and 1"
Simple. 1 isn't different enough from 1 to be interesting. Unless 2=1..... (cue Don Atkinson)
Posted on: 18 November 2004 by Tim Danaher
Thanks Omer, LTD
All seems abit arbitrary/semantic to me...oh well, off for another crack at the Riemann Hypothesis
Tim
Tim
Posted on: 19 November 2004 by Deane F
Nothing could be more arbitrary or semantic than mathematics. It is arbitrary because it exists only inside the heads of human beings and semantic because it derives meaning in the same way. Prime numbers are just a consensus among people practicing mathematics.
Good luck with the Riemann Hypothesis.
Deane
Posted on: 19 November 2004 by steved
Quote from Deane F
"Nothing could be more arbitrary or semantic than mathematics. It is arbitrary because it exists only inside the heads of human beings..."
What on earth do you mean?
Steve D
Steve D
Posted on: 19 November 2004 by Tim Danaher
SteveD --
I think Deane's taking a stance on the old chestnut "Does mathematics have an objective, independent reality or is it merely a cultural/social construct of the human mind?"
Tim
Tim
Posted on: 19 November 2004 by Martin D
Aaaah...suddenly, it's all much clearer...
Tim
Tim
Posted on: 19 November 2004 by Lo Fi Si
Deane
But it also has a lot to say about the “real” world. Godel’s theorem is my favourite (although probably not a very good ) example.
I find it fascinating that mathematical models can predict the behaviour of the physical world so well – it makes me think that there is some underlying “truth” in mathematics that goes beyond it just existing in the heads of humans.
Simon
Posted on: 19 November 2004 by justiceklopper
i still have nightmares over the fluid dynamic lectures where the professor would cover an entire blackboard with one partial diffferential equation....
It probably is an old chestnut but most things are in philosophy. Mathematics is a useful tool but it is just a tool. It is a language with no redundancies so it is precise where precision is needed.
"I think Deane's taking a stance on the old chestnut "Does mathematics have an objective, independent reality or is it merely a cultural/social construct of the human mind?""
I wouldn't say "merely", but it is a cultural/social construct. But then, it could be argued that everything is, which would eventually cause my original statement to collapse back to solipsism if I tried to defend it. Occam's razor helps me to keep the entire cosmos from being included in every statement but puts me in a spot of bother when I'm making a proposition about a thinking tool such as mathematics, which is so universally used that (like logic) it's assumed that the world simply works that way.
Mathematics is an abstract system of symbols sufficiently complex to express arithmetic so, just like Godel said, it will be possible to make statements using that system of symbols that will be neither proveable nor disproveable given the rules of that system - like the mathematical possibility that a sphere can be divided into three parts' and then two spheres, each of equal volume to the original sphere, can be made using those parts. I'd like to see that in the real world.
Deane
Deane
justiceklopper
Has chaos theory simplified the modelling of turbulence in fluid dynamics?
Deane
Posted on: 19 November 2004 by NB
___________________________________________________________
I have a first in Maths but realistically havn't used it in real life.
NB
NB
Posted on: 19 November 2004 by Bob McC
Bugger a first, has anyone ever
needed to divide fractions in real life?
Bob
Bob
Posted on: 19 November 2004 by Don Atkinson
At 1 with the universe
The universe is the way it is. Some of us think we understand some aspects of it....
Maths helps us describe some of its features to one another and helps us predict the outcome of certain events. Sometimes quite accurately, sometimes not.
It is also part of our language, just like words, which help us express ideas and emotions
Maths, language and writing are fundamentally abstract, human inventions, but nevertheless, incredibly useful.
Whether 1 is a prime or not is almost irrelevant and virtually semantic.
"a number that is only divisible by itself and 1"
Our invention of words excludes the number 1, otherwise we would have tortollogy
Of course we could extend the definition with either "including 1 itself" or "excluding 1 itself".
n! + 1 = a prime (but doesn't generate all the primes and doesn't "prove" whether 1 is a prime or not)
Now, allow me to invite you to the "brain teaser" thread to see whether anyone can explain why n! + 1 = prime (and BTW, this would then demonstrate that there are an infinite of primes....
Don
Don
has anyone ever needed to divide fractions in real life?
Bob,
you have obviously never had children...."you three can share half this cake between you..."
Mind you, if I read Charles Clark correctly, having a first in maths AND having the amount of experience described above, should qualify you, and ENTITLE (pun intended) you, to be a high court judge or prime minister.
And judging by the present incumbant in the latter role, i'd say he has a point.
cheers
Don
Bob,
cheers
Don
Posted on: 19 November 2004 by BigH47
They still have a third each though. In this case a third = a sixth.
Bob
Great post(s)
Great post(s)
BigH47,
I have a feeling you could scare Prince Charles rigid......
cheers
Don
BigH47,
cheers
Don
Posted on: 19 November 2004 by Kevin-W
Originally posted by Martin D:
http://www.utm.edu/research/primes/gifs/gammadef.gif
I was going to ask, "Well, what i want to know is, how did you get those symbols?" but having just quoted them I've found out.
Kevin
There is an obscure legal pun in there somewhere Don. I haven't found it yet but I'm working on it. I feel I have a duty of care to find it....
Deane,
...I feel I have a duty of care to ....
correct my spelling of tautology......
Don
Don
Posted on: 19 November 2004 by Joe Petrik
Don,
And here I was thinking you really meant to say tartology, the study of tarts -- whether the pastry or the "honey in a miniskirt" variety I'll leave up to you.
Joe
Joe
Posted on: 19 November 2004 by Dan M
Joe,
Is there also a pieology?
Dan
Dan
Posted on: 20 November 2004 by Don Atkinson
Deane,
he!he!....the penny just dropped....better go back to school....now, would that be taughtology?
Don
Don
Posted on: 20 November 2004 by Joe Petrik
Dan,
Mmmmmmmmm, pi.
Joe
Mmmmmmmmm, pi.
Joe
