How to clean the case
Posted by: Alco on 25 January 2001
Hi guys,
Does anybody know how I can clean the case of
my Nait-2 ? It doesn't look that nice and black
anymore. It's got some white stains on it.
(wich only appear when the daylight is shining though..)
Is there a simple method or fluid to clean this
rough metal surface ? (old Granny's secrets)
If not, well, no big deal, but thanx anyway.
Greetings,
Alco.
Posted on: 25 January 2001 by Martin M
Get some non-silicon based furniture polish and spray it on a sponge. Rub the case with the sponge. Et voila! A clean case.
Posted on: 26 January 2001 by Alco
Thanx for the tip, Martin.
I tried it, but it didn't work (for a long time)
Now, I tried something else. (very cheap and
almost too ridiculous too mention..)
I took a little water, heated it, in a kettle, till it cooked, then let it cool of.
With that water I rubbed the rough surface of the
Nait-2 and et volla, hahaa it even worked!
The stains are really gone.
(Even I don't know how I came up to this idea..)
O,well. case closed, problem solved.
See ya' guys
Alco.
