P2P networks
Posted by: Minky on 21 October 2004
Is it possible to join one of these "communities" without getting done over by adware, spyware, viruses etc ? If so which one should I join ? I want to download music for my iPod on the basis that if I like it I'll buy the CD and if I don't, I'll nuke it.
Or this naughty ?
Posted on: 21 October 2004 by John Sheridan
Or this naughty ?
that's entirely sensible but the record companies would have you locked up - you're meant to buy all their excellent offerings without listening to them first.
Someone once told me that eDonkey may be worth a look but make sure you don't install all the extra cr*p that comes with it.
Posted on: 22 October 2004 by pingu
EMule uses the EDonkey network but without the adware spyware crap. Its a pretty good little search machine too.
EmuleAlso recommend you get the VLC player and the plug in as this can read the half downloaded files (so you can abort incorrectly name downloads)
C.
Posted on: 22 October 2004 by garyi
I use limewire without problems
Posted on: 28 October 2004 by Madrid
Emule has received good feedback from the P2P community, but it seems to be incompatible with the ZoneAlarm firewall (which I installed at the recomendation of someone on this forum and has been otherwise flawless).
So, I installed Limewire, which seem to be quite fast.
Cheer,
Steven
Posted on: 28 October 2004 by Paul Hutchings
Or this naughty ?
WinMX, or good old Usenet.
Paul
