Earthing
Posted by: Naheed on 30 December 2000
A while back i had earthing problems (leading to audbile hum through my speakers), so the guys at Naim suggested using the TT binding post to earth the preamp to my ac socket (this worked really well - but later i found out it was a faulty snaic at fault).
However, i still leave the TT earth connected, and at the moment i don't want to start experimenting on/off benefits, as i'm still getting used to some recent upgrades.
Anyone, tried this, doing this ???
naheed...
Posted on: 30 December 2000 by FangfossFlyer
What is a TT post? confused
And how did you connect it to the mains a/c earth (via a standard mains plug?)
Posted on: 30 December 2000 by Former member
Naheed,
I'm curious. How exactly do you connect from the 102 TT post to the mains socket. Sorry if I'm asking a really obvious question, but I would like to try this.
Ajaz.
Posted on: 30 December 2000 by Naheed
I just used a length of solid core wire, attached this to the TT (turntable ground - in between your bnc's), then attached the other end to the earth pin on a standard plug and plugged that into a spare outlet...
naheed...
