Stageline
Posted by: John C on 19 January 2001
Hi. Does anyone know if the phono boards in the Stageline can be swopped. ie If I buy a MM Stageline tomorrow but a low output MC next year can I swop the internals? Also is the MM stageline ok with Dynavector 10x4?.
John
Fully into new vinyl replay by stealth mode.This message will self destruct in 30sµ
Posted on: 22 May 2001 by Kevin Hughes
I understand the boards in the stageline cannot be swaped, it may be possible to get Naim to mod them from MM to MC at some point down the line. Ask Naim direct.
The 10x4 is designed to work into MM boards, and it does work with Naim MM boards.
Kevin.
