Dynavector 10x4mk2 with 82 S-boards....
Posted by: Laxton on 26 November 2000
I'm presently running an 82 with cdx/nat-3/180/epos22 as the rest of the system. Can the dv-10x4mk2 high output MC work with the S-board of the 82 preamp? Does anyone have any experience on this cartridge esp on a planer 3? I'm very new to the world of vinyl and any help would be most appreciated. Thank you.
Laxton
I do not think that the S-boards will work with the 10x4. The S-boards are designed for low output moving coil cartridges. The 10x4 is a high output moving coil.
The output of the Dynavector 10x4 is that that it should be used with moving magnet boards.
Hope that helps!
Mark Russell
Recommendation: buy a low output MC or the MM boards.
Regards.
Phil
Laxton
[This message was edited by Laxton on MONDAY 27 November 2000 at 16:17.]
The ability or inability to work into the different boards is more than just a function of gain- to which has to be added the loading impedence of the board and possibly the available headroom on the pre-amp. In this case it may well have been that the 100 Ohm load on the MC board was a much better match for the 10X than the 470k load supplied by the MM boards.
Later on the owner of the P3 upgraded to an LP12/Ittok and from the standard ARC 101 to an anctive configuration. Even in this fairly high resolution setup there was nothing to suggest the MC boards were being overloaded by the 10X.
So by all means try out some S-boards, and maybe even some E-boards as well as the standard MM ones. Your own ears, not the technical specifications will very easily tell you which one is the best match.
Ron
Dum spiro audio
Dum audio vivo
I would've consider the MM or other boards if i didn't already have the S-boards which came together with my 82. The boards have never been used. Just to give a little more information, i am thinking of purchasing a p3. Now i am venturing into the unchartered waters of vinyl and also to score some FEPs
That is the reason why i really do not know much about the techinicalities nor do i have any experience about vinyl setup. Do you have any advise for a newbie?
Laxton
Laxton - The correct boards to use with the 10x4 are the MM boards (522's). The Dynavector is higher than a Rega cartridge so you should mount a 2mm or 4mm spacer under the arm (can't remember which exactly) to give you good VTA. In my view, the P3/10x4 combination is a very good one indeed and we consider it to be as far as you'd sensibly take a P3.
As you already have the S-boards, you could consider an Ortofon MC25FL (around £250) or Dynavector 20XL (£300) which will work well into S-boards. The MC25FL has fabulous timing for the money, though it has an 'enthusiastic' treble. The 20XL has more tonality and is my choice therefore. In general, there are significant gains to be had by going with an MC, usually in terms of clarity, detail, and pace.
Frank.
Ron - you don't half come out with some crazy stuff sometimes.:) The reason you had to keep the gain down on the volume control of your Nytech is because the load was wrong - keeping the volume down simply meant you wouldn't overload the output stage of the amp causing amp oscillation eventually.
Well part of the craziness was the fact that at the time (circa 1980) I was an impoverished student esconced in a university dorm in the north east of Scotland. Gear with any Flat Earth Pretensions was far and in-between and we played with what little was available. It was not really the load that was wrong (some MC cartridges work quite well into the 100 Ohms) but the gain/sensitivity :-). This technically mismatched combo was resident in an active system and served its owner for two years and provided by far the best PR&T Flat-Earth sound in the entire dorm (this lads neighbour had a LP12/Ittok/Asak/Nytech which was pounding a pair of supremely coloured KEF 104 ABs with the worst of both worlds... ?a concave earth sound?) The standard Nytech MM boards were a little too low in gain for the 10X- which was quite a bit lower in output than say an Ortofon VMS20, or an ADC XLM, and the volume slider with these boards had to be well advanced with the attendant noise and poor dynamics. Also the different boards had to be dealer installed which required a bus trip over to Edinburgh or Montrose, so frequent swapping and chopping was not really convenient.
If you think that this was crazy, how about the only naim-owning dorm resident.... the front end for his 32/160 was a Technics direct drive turntable!
Ron
Dum spiro audio
Dum audio vivo
From the US Naim Audio website:
"cartridge type: S - standard low-output MC / K - wide-bandwidth low-output / E - medium output MC. Stageline also available in N - MM / high-output MC type"
I use the 10X4 MK2 with the K board. No problems at all, and it does not overload even at very high volumes. So should not be a problem with the S. It would actually be good, preserving the super dynamics of Naim. Recommended by Ben.
You are welcome to visit me one of these days for some vinyl listening session ...
Phil
Note to Mike Pranka: Are you still the DV importer? If the 10x4 not a high output MC?
[This message was edited by Phil Barry on SATURDAY 02 December 2000 at 20:02.]
I would love to hear what those black spinning things can do. Although i have to admit that i've only heard them once thoroughly in the showroom. Expect an email down your mailbox soon
Laxton
Malcolm
