NAC A5 Service
Posted by: Naheed on 03 September 2000
Ok, chaps at what sort of intervals (6 mths ???) should one chop back and re-solder these joints,
I am upto nearly 2 yrs now... (is this bad.)
naheed...
Posted on: 03 September 2000 by Rico
Naheed, if your connectors are correctly soldered and there is no exposed copper to oxidise in the contact area, there is no need.
Re-terminating is to eliminate poorly-terminated joints (bad mechanical or poorly soldered joints).
enjoy yer music. Or try new NACA5.
Rico - musichead
ricomuzik@hotmail.com
