Mana - Setup findings
Posted by: John on 01 January 2001
I recently changed the setup of my Mana stand. I thought I would post as it might help other people.
I originally had my stand standing ontop of my oak cabinet that houses my CDs. The stand spikes sank about 1-2 mm into the oak finish. I changed this by putting 1 inch MDF board ontop of the cabinet that the stand now sits on. This seems to have tightened the image further.
Is this the best setup or what is the ideal?
John
Posted on: 01 January 2001 by Former member
John,
I believe Mana is designed to be coupled directly to load bearing surfaces e.g. solid wall or floor. If you are mounting your Mana on a moveable object such as an oak cabinet, I doubt you are maximising the Mana effect. Try placing your stand on the floor and see if it sounds better.
James
Resistance is Futile
