Buying a budget turntable
Posted by: nodrog on 10 December 2001
My amp is a CDNait 2 with just ordered Gram Amp 2. This is sounding rather good at the moment with dedicated mains supply and Rocksolid speakers, which I previously posted on but no-one took any interest in...must be too cheap, I guess!
Thankyou,
Peter
PS: I became a proper 'member' at last. Hurrah!
regards
Dev
What does 'the panel' think of the Music Hall MMF-2.1 as a possible purchase?
I have never heard one, though IIRC it was designed by the same person as the old Revolver range so should be ok. My advice though would be to scrape the little extra together and land the all time budget classic, a Rega 3. The Planer 3 is the deck to beat in lower price range, is proven, reliable, and virtually indestructible. Stick a decent cartridge into it, plonk it in the right place and you have a turntable that can embarrass some very expensive digital front ends. The new P3 is allegedly even better than it was having better pitch stability. The RB300 arm is a true classic and is unbelievably under priced.
Dev's option of a cheap LP12 makes a lot of sense in the UK, but I notice you live where there is no such thing.
Tony.
PS Dev, you find me a CD player that sounds like a top flight Xerxes and I will swap a CDX for it!
The MMF-2.1, however, is available for purchase on the internet for the v. good price of USD299 and has some good, even excellent reviews. So long as it's slightly tweakable and slightly more listenable, I think it's worth a try.
Thanks,
Peter
Phil
Cheers and good luck !
Bob
I have seen the P3 here but it is 76000yen (abt 400GBP), which I think is excessive as the reviews are only so-so.
Don't pay too much attention to reviews in general, and Rega in particular. Unless things have changed recently Rega never provided review product to magazines, and never had any desire to get their products reviewed, even more significantly Rega never bought advertising space. The combination of no advertising revenue, no free or heavily discounted review samples etc made a magazines motivation to give glowing reviews a little less obvious. I'm not saying that all magazines work on this basis, but there are a hell of a lot of backhanders going on in the audio industry.
The P3 is a great deck, I am convinced that opinion will be consistent throughout everyone who has heard one here, and that is probably the majority. How it compares with the Music Hall I can't say. How about considering a second hand P3? They hold their value incredibly well, you would get back the same or more when you came to sell it, and it would definitely still be working at that time.
Tony.
M
I parted with mine when I hooked it up to my more-revealing Naim gear (not much up from what you have, BTW) and heard a steady grunge sound under everything. I had not oiled the bearing - ever! The bearing well dried out and the bearing went.
So...do listen and check the bearing before you buy.
I *may* just part with my LP12 and get me a new P3. I love the way they are not fiddly and have a more modern look to them than an LP12.
- Greg
Insert Witty Signature Line Here
"The new P3 is allegedly even better than it was having better pitch stability"
I've heard mixed reports about the new P3 (strictly speaking, the old version is called the "Rega Planer 3 and the new one the "Rega P3"). Some people say that, with the new plinth and/or motor mount, some of the charm of the Planer has been lost. Frankly, if you can find a good example of either version second-hand, buy it. If you end up buying new, don't worry about the difference.
Timo
P.S. the lime green Planer 3s are thought to sound best, but I'm a sceptic myself since hearing the shameful sounds coming from Jawed's Rega of that colour. I wonder if his bearings are knackered or maybe it's just the 300 year old stylus.
My God - "Rega in Cirkus-like fiasco - shock! horror!"
cheers, Martin
Somebody said that every vinyl enthusiast has had a rega at one time or another. I've had one, twice, and they get to the heart of the music and easy to sell on after.
Their number one virtue, for me, is their plug'n'play simplicity.
Peter
I guess I'll be buying a lot more records from now on. I've found a Simply Vinyl release of Tom Waits Swordfishtrombones which sounds wonderful Does anyone have any more from this label? How much are they in the UK?
Thanks for all your (persuasive) advice on this!
Peter
Oh, congratulations on your P3. Good luck on your hunt for vinyl.
Regards.
Phil
Should I max out on MC cartridges, buy a Rega EXACT cart, or wait until I have the resources for a P9?
The P25 at the moment is not as musical as my CDX.
Placing the P25 on a QS Ref. shelf may improve matters, I know - it is currently on a Rega shelf.
I'm not interested in an LP 12, as it would sound better on Mana, which I refuse to buy on personal principle...
It's always a nice day for it
Have a good one! ![]()
Steve.
It's good to get back to normal. ![]()
