What is the Minimum Pre-amp/amp that can drive my Dynaudio 1.8's
Posted by: Jaybar on 20 April 2001
I am not looking to surpass my sound from my Spectral gear, only looking to make hifi life simpler., fun and engaging.
Will a Naim 112/150 drive my Dynaudio 1.8 Mk II's. what is the minimum amp I would need?
Dealer suggested that further improvements in pre-amp and/or added a power supply would be needed to make this sytem fully competative and/or out perform my Spectral MIT system. Nevertheless, I was very impressed with the 102/180 combo-even without a power supply.
We did not have time to explore Vinyl playback, via a Linn,Linto, Lingo( My current configuration). I am concerned how the Linto and Pekin Tuner would perform with the Din->RCA Interconnects from Chord. Currently, I am using Linn Silver IC's.
There is also the unanswered question of behavior at home. My home environment, relative to equipment stands, acoustic treatment, choice of furnishings is geared toward making my Spectral based system as good as possible From what I heard today, the Naim and Spectral systems were different, both with respect to Tonal Balance and strengths which suggests that if I proceed further to consider Naim, I must do extensive home audition. Another factor that needs consideration is the resale value of my Spectral/MIT gear. All these things not withstanding, there is real potential here.
Jay
BTW are uyou using the Lyra Lydian Beta. On what tone arm if you are?
Jay
The L-200 pre amp (1200 UK pounds)and HX-75 poweramp(2195 Uk pounds) .
IMO, a cross between Naim and Linn, taking the best bits from both! Still RCA, so no problems with the Linto. For a comparison, it gives a 82/180 a very very good run for its money. The power amp has lots of current too, to drive your Dynaudios.
Just a thought!
Goose
If you've got Spectral gear, I suspect the 5 series is not going to be a total improvement. The least you should do is spend the same amount of money on Naim gear.
Phil
I am discovering that in order to get a performance level equal to Spectral with all the virtues of Naim, I would need to spend the $$$$ you suggest. I thought more entry level gear would do it and it won't.
I may have to put the project on hold until I replenish my bank account in 2-3 years. Such is life.
Jay
