Best Speakers with Naim setup
Posted by: CmpMeridian on 01 February 2009
What are the best speakers to use with Naim setup?
Posted on: 02 February 2009 by Jay
Naim speakers?
I have the nsatx4, ncent and nsub.
J
Posted on: 02 February 2009 by The Strat (Fender)
Welcome. To go with which Naim components?
Naim are the obvious options but depending on how much room you might have (different speakers react differently in different rooms) Naim electronics will go with any different number of brands. I guess the most popular are possibly Neats, but the only thing to do is get some demos preferably in your own home.
Good luck.
Fender (Strat)
Posted on: 05 February 2009 by musfed
Neat speakers do it for me as well. The Naim speakers I listened to didn't make me happy. Sonus Faber GUARNERI MEMENTO did the job as well. (understa Razz tement times X)
Posted on: 05 February 2009 by Massimo Bertola
I seem to be able to recall having auditioned Naim gear with: Sonus Faber (various types), Klimo, Penaudio, Marten Design, and Naim. I have SBLs, and if I should buy speakers today, I'd buy n-Sats.
Posted on: 06 February 2009 by u5227470736789454
We listened to Neat, Audio Physics, Sonus Faber, epos, avalons - and went for the A/P's as they ticked the box for both sound and WAF
Barrie
ps we don't have access to Naim speakers over here so I never got to hear them, and I only got to hear the Neat 1 and 2 as they were the only ones available, so I may have missed a trick there, but I have to say I'm very happy with the A/P's
Posted on: 06 February 2009 by lawoftrust
Maybe You will give the Linn Akurate Series (242) a try. These speakers match quite good with Naim to my experience, if can easily be extended to a full home cinema set and due to its neutral sound they shouw you every detail of the Naim sound. However, the amps should match the requirements of this speaker, i.e. at least a Nap 250.
Linn Majik Speakers shall also work very well with the smaller amps.
